headlight upgrade 280i
LarryK
Hella makes a good halogen upgrade. They come with H4 halogen bulbs with 55W low and 60W high, which then can be upgraded again with the new IPF 55W/100W HD light that has the same 55W output without messing or upgrading your wiring.
tr7andtvr
tr7andtvr
I got my “85” 280i about 2 years ago and the headlights have never moved electrically, they always have mechanically. Once removed and hooked up to a +/- they spin fine. My assumption is that ½ of a revolution is up and ½ a revolution is down.
On the LEFT side:
(2) White and Purple in a single plug that give a + when lights are ON
(2) White and Yellows in a single plug that give a + when lights are OFF
Triple Plug:
Black (QUESTIONAL GROUND)
Purple and Blue (NOTHING)
Purple and Red that give a + when lights are ON BRIGHT
On the RIGHT side:
(1) White and Purple in a single plug that give a + when lights are ON
(1) White and Yellows in a single plug that give a + when lights are OFF
Triple Plug:
Blue and White (NOTHING)
Blue and Red that give a + when lights are ON BRIGHT
Any ideas on what’s wrong?
tr7andtvr
tr7andtvr
I replaced all my relays (again)... Now I can get them to turn 1/2 a revolution when the switch is turned on. But nothing when the dash switch is turned off. The motors are doing the same thing no matter what side I connect it to. Thoughts?
GT6_Mark
I don't know this as fact and do not have a wiring diagram to hand to confirm, but I seem to recall that there is a diode in the motor circuit that controls some of the actions. If so, the kind of issue you describe could be explained by a bad diode. I'd ask over over on the Triumph board to see if a TR7/8 guru has any ideas.
Guido36 LED Headlight Upgrade Austin Healey 1
TomMull General Tech Headlight upgrade Triumph 9
CinneaghTR TR4/4A Headlight Upgrade for TR4A Triumph 11
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
K TR4/4A 4A chrome headlight rim installation? Triumph 2
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
S Replacement Headlight Switch Spridgets 4
jaegzie Headlight buckets Spridgets 3
B Sizes of Headlight Bucket Recess Austin Healey 8
CJD TR2/3/3A Headlight bulb rating Triumph 18
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
