Headlight buckets
Gerard
Am I able to use the housing from a mk4 sprite in the be bonnet. Before having to get a set of fenders down thought Id ask if anyone knows. Thanks.
Yes, should not be an issue. Later buckets have slightly different adjusters, but they should be in the same location. Later buckets use a snap on headlight ring instead of the type secured by a screw. like the original Bugeye ones would have.
I prefer the the later style adjusters. If you ask around you will probably find someone with old style buckets laying around that they will sell cheaply.
Healey Nut Headlight buckets Jaguar 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
sqbsprite TR6 Question about headlight buckets Triumph 9
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
K TR4/4A 4A chrome headlight rim installation? Triumph 2
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
S Replacement Headlight Switch Spridgets 4
B Sizes of Headlight Bucket Recess Austin Healey 8
CJD TR2/3/3A Headlight bulb rating Triumph 18
Tinkerman TR2/3/3A 1960 TR 3A square spier nuts on headlight assembly Triumph 2
C TR2/3/3A Weak headlight Triumph 7
