Headlight Trim Rings on my BE - Removal - Best Methods
Jim_Gruber
So the headlights on Bugsy my 60 BE appear to be OEM Originals. That would imply the Trim Rings have not been off of the car since color was changed to a Ford Blue from the original Nevada Beige many, many years. One headlight has a burnt out lower beam and is blackened around the top of the headlight housing and the other is just dim period. Going to Halogen and Relays, purchased a kit off of Amazon which consists of a set of ceramic sockets, male sockets that the original wiring plugs into, Relays, fuses, power and ground. Simple to hook up and this will work until new harness is purchased which will incorporate a set of relays. For $25 I can't take the time to source materials, build it up, and install. Time is money as well. And since I could not find non Halogen lamps in O'Reillys last week this will work tewmporarily.
So the big question, any other bright ideas on removing the trim rings which appear to be bonded to the rubber gasket other than a very long strap wrench wrapped around the headlight ring. These will be replaced eventually as chrome is fogged but they just might buff out so don't want to damage if I can help it. And of course I can't find my strap wrench, Time for a trip to the hardware store.
Gerard
The original Bugeye headlight ring is secured by a single screw at the bottom. If it is present, it is accessible via a small hole at bottom of the recess in the bonnet. Remove the screw, and use a wide blade screw driver or putty knife as near the bottom as you can access to pry the ring forward. it will pop off. I think you'll more damage with a strap wrench... not sure if that would even work.
Jim_Gruber
Jim_Gruber
Glad I asked Gerard as that is not the way the trim rings were on my '68 that my brain was using for reference. Repair to lawnmower first then Bugsy is on the list for today.
59diamond
Until recently I thought the holes under the headlights were to let rain drain. Now i know that they are there to adjust the headlights and remove the trim rings. I bought new trim rings for my BE from I think the Little British Car Company and they look great. I still have the old ones that could be original that you can have if yours wont shine up. Anyway they don't cost much to replace.
59diamond
Actually I got them from Moss. They are part number 164-002 and are $21.79 each or $43.58 for a pair .
I will send you a picture of my old ones and my new ones.
Jim_Gruber
Jim_Gruber
Thanks Bill, I'll let you know.
Stinger TR4/4A TR4A Headlight Trim Rings Triumph 4
RickB Asking here too - removing headlight trim rings? Spridgets 4
RickB Need Tip to remove stubborn headlight trim rings MG 3
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
D TR2/3/3A Headlight Trim Triumph 17
T TR4/4A Attaching headlight trim ring Triumph 6
JPSmit Question four - headlight trim ring Spridgets 9
5 TR2/3/3A Headlight trim removal on TR3? Triumph 3
NutmegCT TR2/3/3A Headlight trim ring TR3 Triumph 6
I TR6 Source for 69 TR6 headlight trim ring? Triumph 7
M Chrome Trim Ring on Headlight Gone Spridgets 7
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
P TR6 ^%$#headlight rim Triumph 4
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
K TR4/4A 4A chrome headlight rim installation? Triumph 2
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
