TR6 ^%$#headlight rim
pdplot
OK. What's the secret to re-installing the headlight rim? I got one on due to the fact that it was slightly bent but spent 45 minutes pushing and twisting the good rim but no soap. Stupidest system I've ever seen. Could have been solved with one screw in the bottom - in fact the left rim did have a hole for a screw.
TR3driver
Great Pumpkin - R.I.P
Turn the removal tool around backwards and slide it between the rim and bulb retainer at the bottom. Use the end of the tool to push the tab into the clip.
The hole was used on TR2-TR3, which did use a screw to hold the rim. But when the front was redesigned for the TR3A, the headlights were moved backwards until it was difficult to get a screwdriver onto that screw. Hence the clip arrangement. (There was also a brief variant with a horizontal machine screw.)
P
pdplot
1. I have no tool. Used a screwdriver to widen the gap as set forth in the shop manual.
2. I assume the little tab on the rim slides under the larger tab on the bottom?
It came off easy enough. It doesn't seem to catch nowhow.
TR3driver
Maybe that's the problem, the clip is bent until it doesn't catch?
This clip is broken (obviously) but maybe you can see how it goes together.
Any thin, flat strip of metal should do in place of the tool; for awhile I used one made by grinding the teeth off of an old hacksaw blade. An old IO slot cover from a vintage PC would do, too.
P
pdplot
OK Randall. Thanks. I don't know how or why, but I finally got the tab to catch and the rim is on - maybe. The whole light is a bit loose in its socket. One thing for sure. It's never coming off again, at least by human hands, even to aim the headlights. Besides, I don't drive this car at night anyway. Not if I can help it.
D Wanted TR3 Headlight [lamp] chrome rim Triumph Classifieds 1
K TR4/4A 4A chrome headlight rim installation? Triumph 2
G TR2/3/3A Headlight Rim Triumph 7
A TR2/3/3A Hilarious TR-3A headlight rim story Triumph 2
Rut Bugeye headlight rim attachment part Spridgets 18
I TR6 rivets/bracket source for TR6 headlight rim? Triumph 5
H Headlight Rim Fasteners Austin Healey 4
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
F TR2/3/3A Headlight bucket color Triumph 22
F TR2/3/3A Headlight bucket clip Triumph 2
Healey Nut Headlight buckets Jaguar 3
B Headlight Dip Switch Austin Healey 4
D TR2/3/3A headlight question Triumph 8
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
Bocaray TR2/3/3A Headlight Dimmer conversion to dash switch Triumph 6
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
Rob Glasgow For Sale Used headlight rims for sale Austin Healey Classifieds 1
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
Guido36 LED Headlight Upgrade Austin Healey 1
Healey Nut TR6 Headlight size Triumph 58
D BJ8 Headlight Rims Austin Healey 0
D TR2/3/3A snap on headlight rims restore Triumph 10
steveg TR6 Headlight switch - can it be rebuilt? Triumph 4
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
K TR2/3/3A Headlight Hi beam floor button fail? Triumph 5
dbenichou289 TR2/3/3A headlight switch removal Triumph 10
Spock TR6 '72 Headlight Relays Triumph 4
Upland 3 position headlight switch is now 2 Spridgets 1
AUSMHLY Led headlight conversion kit with Lucas headlight bucket Austin Healey 37
D TR2/3/3A Headlight Trim Triumph 17
KVH General TR Headlight going out Triumph 9
Rob Glasgow Weird Lucas Headlight Austin Healey 7
P TR6 Headlight problem Triumph 3
M Headlight relays Austin Healey 17
T TR4/4A Attaching headlight trim ring Triumph 6
S TR4/4A Headlight switch wiring. Please help Triumph 2
GTP1960 TR2/3/3A LED headlight question Triumph 11
T Question regards headlight ring 'thickness' for bugeye Spridgets 3
S TR2/3/3A Tr3 headlight buckets Triumph 3
healeyblue XK 120 headlight mounting Jaguar 1
Jim_Gruber Headlight Trim Rings on my BE - Removal - Best Methods Spridgets 5
4tecdog Headlight relays the easy way Austin Healey 13
M For Sale E-Type S1 Plexi Headlight Covers Jaguar Classifieds 0
Rut Headlight relay question Spridgets 3
JPSmit Question four - headlight trim ring Spridgets 9
princetn1 MGB Headlight Grille MG 7
TomMull General Tech Headlight upgrade Triumph 9
S Replacement Headlight Switch Spridgets 4
jaegzie Headlight buckets Spridgets 3
