280i Ford 302 Conversion
tr7andtvr
I am getting towards the end of this conversion. Would anyone like a “how to” guide on doing this conversion, or would I be wasting my time typing it up? Since I have done the hard part in trial and error fabrication, it would be an easy conversion for someone to do. The conversion does consist of the removal of 2 pieces of tube and the addition of 3 mounting plates. Everything ells came off the shelf. If I get some real interest I will look into posting a link to detailed instructions.
This will also work on a 289/302/351w
GoBritBaby
It would make for an interesting article in the TVR Times. You should consider submitting it.
mrtvr
Yes, I fully agree, and I would welcome the submission and applicable photos for a future TVR TIMES issue.
Marshall
i would be very interested to read whatever you have to write and see some step by step pictures too! i am considering the possiblility of a similar swap in the future if i buy the TVR i am looking at.
tvr280
I would be very very interested in a how to. It would probably give me the push I need to get going and would be much appreciated.
Grady
Member
If you do write it up, I hope you could share a final parts list and the templates for the above mentioned plates.
Too often these good conversions stories say "well, none of these parts worked but I finally found one from a (fill in the blank) that did" without giving away the secret part number or enough info to save reinventing the wheel.
Thanks Grady
tr7andtvr
tr7andtvr
I will do PDF's of the frame mods, and mounting plates and I will give all part numbers and manufactures. I am only going to list the parts for the conversion. I think that I will have the car finished by the Smokey Mtn Show May 12 if anyone wants to put their eyes on it. I just need to find time to finish this. I am expecting this car to have better performance than a 400 or 420. 0-60 around 5.0 and a top speed around 160 mph. A Panoz Esperante is getting 5.1 and 155 mph with the same drivetrain and 900 more pounds. But we will see….
mrtvr
I look forward to seeing the finished project at Springtime in the Smokies in a few weeks. I'll have my "barn find" 280i there as well.
tr7andtvr
tr7andtvr
Ill give it about a 75% chance of getting there...
There was a very good tvr turn out there last year, I think there were 7. I think the TVR guys that were there were more intrested in "The Dragon" than the show.
tr7andtvr
tr7andtvr
The car is alive….
It has just been the little things that have been so much trouble. I hope to get the slave cylinder on this weekend and then it will be time for the muffler shop. If anyone is trying this at home or is doing a t5 conversion. Make sure you get a t5 from a 94 or newer mustang. A vw slave is a direct bolt in to the bell housing and to the existing line. But in a 95 you have to build a mounting bracket. If I did this again I would buy a entire 88 mustang and then let the junkyard have what’s left after I am done. I am also playing with a cold air intake for the Holly.
G
I'm only nitpicking because I'm interested:
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Make sure you get a t5 from a 94 or newer mustang[/QUOTE]
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If I did this again I would buy a entire 88 mustang and then let the junkyard have what’s left after I am done[/QUOTE]
On the face of it, these two seem mutually exclusive.
Which is it?
Or am I having a senior moment?
tr7andtvr
tr7andtvr
Sorry t5 from a 94 or older..... In 95 they updated the t5 in 96 they went to the cobra 4.6 engine. That makes a 95 5.0 a odd bird. Odd starter and odd bellhouseing.
tr7andtvr
tr7andtvr
For some reason I could not make any power. It felt like my 302 was a 4 cyl. I started unplugging plug wires and found that I had 4 dead cylinders. So I revisited the firing order of a 302, and I was hooked up right. Just for the fun of it I looked up the firing order on a 351. Then redid my wires. WOW, I HAVE A 351! The head sits a little higher in a 351 and that explains why my exhaust was sooooo hard to fit. But now it is in and everything is looking better. So now I guess instead of a 280i I have a 580?
aztvr
Member
I'll bet that was a tricky thing to figure out !!!! I've read that you can get aftermarket cams in either firing order and they fit in both engines, so, you could have even have a 302 engine with a cam that was made with a 351 firing order. Not being a follower of American iron, I would never have guessed that.
Isn't working on cars fun ?!!
tr7andtvr
tr7andtvr
By the time I push my foot all the way to the floor I have hit 5000+ rpms. My left foot cannot keep up with my right foot (so I have to hold back). And the rear wheels could spin at any rpm even in 3rd gear at 3000 rpm on a straight dry road. And I have 245/45/17... I am still working out some electrical bugs.
tr7andtvr
tr7andtvr
The Griff is a little lighter isn't it? Its a big sound out of a small car. The engine conversion is done now I am trying to get a top and some carpet in it before a local May show. I also need to redo the brake master.
mailbox
I would be VERY interested in seeing and reading what you have done. I believe I could use some of your tips for my own languishing project.
MatthewsTVR
Any list you may compile would honestly be great to look at. I am considering one of these conversions on my 1985 280i and a parts list would be outstanding, just so I can get an idea of how much it may cost.
P.S. I really think that weber idf carbs would look great on a 302 conversion 280i.
Matt
R For Sale Nice TVR 280i For Sale Other British Classifieds 6
J 1985 TVR 280i Speedometer Cable TVR 4
H 280i oil filter TVR 2
G Triple Weber DCNFs on 280i V6? TVR 1
S 280I parts? TVR 0
Feathers 280I radiator TVR 5
H 280i Tires TVR 7
M FOR SALE: 280i 2.8 v6 engine and 4 speed transmission for sale TVR 2
A 1985 280i - stalls when warm TVR 6
J Just purchased an 84 280i from the UK TVR 15
tr7andtvr 280i Rear End 4.20? TVR 0
tr7andtvr 280I weather strip source TVR 1
tr7andtvr carpet pad? 280i TVR 3
tr7andtvr headlight upgrade 280i TVR 4
tr7andtvr 280i seat swap? TVR 8
GT6_Mark 280i Manual to Power Steering Conversion TVR 17
Sparkie New 5 speed conversion for 280i guys TVR 32
tr7andtvr 280i engine conversion? TVR 1
tr7andtvr 280i For Sale [before I put it on ebay] $6500.00 TVR 1
tr7andtvr who knows anything about this 280i on ebay? TVR 2
G 280I/ TASMIN HEADLIGHTS TVR 4
T 280i auction sale Other British Cars 8
H Hey Hayfever, 280i in Austin on EBAY Other British Cars 1
T 1985 TVR 280i Other British Cars 14
H TVR 280i Other British Cars 14
AngliaGT Saw These Today (This is FORD Country?) Spotted 2
AngliaGT '64 Ford F100 Spotted 2
AngliaGT 1969 Ford Galaxie Spotted 3
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 How about an English Ford Folder FORUM Navigation Questions 1
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
AngliaGT New Supra,BaT Ford Bronco Spotted 0
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Lin Ford Versus Ferrari Question Austin Healey 23
C Ford pre-crossflow valve train Other British Cars 2
AngliaGT My Old Ford Consul Capri Other Cars 0
Basil Ford Tractor Spotted 12
O Ford Cars Other British Cars 18
C Wanted Wanted - Ford Cortina "bullet" style gearbox Other British Classifieds 1
H Ford T9 5 speed question Restoration & Tools 1
3798j Ex-Bell Telephone "55 Ford F100 Other Cars 8
C For Sale AC Bristol with a Ford engine Other British Classifieds 0
M TR2/3/3A Ford Alternator Conversion Problems Triumph 10
Paul_1 Vintage Ford Cortina Spotted 12
