Economy Shuts Down Crane Cams
Platinum
That's about as sad a piece of news as I can stand for one day.
Gonna go crawl into a hole now and wait for all this to be over...
RATS!! :madder: :wall:
PeterK
I am shocked about that. My first "hot" cam was a Crane in a 1961 VW, long, long ago.
tdskip
How much do you want to bet that when the company was last sold the company / private equity group that bought it leveraged the snot out of it....
TR6oldtimer
It happens all the time. Not only did the new owners leverage the heck out of the deal, they did not have the love of the business the original owners had. That said, other then for the racing business, I would bet heavily that the demand for street cams is nowhere near were it was 20-30 years ago
TR3driver
Great Pumpkin - R.I.P
Of course; that's how it's done. There are effectively roving bands of predators that wait until there is a bailout in the air; then buy up the weakest companies using all the leverage they can muster; so the company can be sold at a huge profit after it's bailed out. I had a front row seat a few years back, as the Carlyle Group worked their magic on my employer. The WSJ estimated they made some 300% ROI on the 90's bailout.
Apparently this bunch mistimed their purchase of Crane Cams. No problem for them, they'll just roll the dice again with some other company. Losing a fine old business like Crane is just collateral damage ...
Erica MGB Carburetion and MGB fuel economy. MG 0
RJS Triumph TR MPG [Fuel Economy] Triumph 6
dklawson Bad Economy Forces Crane Cams to Shut Down Spridgets 7
RickB Timing for fun and economy - can it be done? MG 44
eschneider homebuilt / economy sheet metal press brakes? Restoration & Tools 0
W Spitfire fuel economy for 68 spitfire Triumph 6
2billydavies TR4/4A yellow blinker light stays on all the time the shuts off when blinkers are used Triumph 2
mcmillal TR4/4A TR4 suddenly shuts down Triumph 25
Wizardd MGB '77 MGB runs for a bit, then shuts down MG 28
M TR6 TR-6 ignition ligt on- car shuts down Triumph 7
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Got_All_4 TR6 TR6 Down Pipe How They Last Triumph 6
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
M MGC New book: MGCs Down Under MG 0
shadowfever Shake down run Spridgets 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
K TR2/3/3A Steering Wheel hold down Nut Triumph 6
Busted knuckles TR2/3/3A Engine tear down, Triumph 13
Rut Cut down windshield Spridgets 22
S TR2/3/3A trim to hold down the furflex Triumph 3
Sopwith_Camel up or down? Jaguar 12
D TR2/3/3A stator tube will not go down Triumph 0
K Austin-Healey Fold-Down Windscreens Austin Healey 27
D Lotus Elan S4, From water pump...to a strip down.. Lotus 2
DrEntropy Diesela won't go down... Other Cars 5
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
A Spitfire Spitfire Ride Down The Mountain - Vermont Rt 100 Triumph 12
wangdango BJ8 inner battery hold down? Austin Healey 4
Got_All_4 TR6 Starting The Tear Down Of MY 1969 TR6 Triumph 6
G Supplier rant from down under Austin Healey 12
RAC68 Cost of Cutting Down an American Rear Austin Healey 12
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
M Hauling a Spridget - Proper tie down technique? Spridgets 15
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
Patrick67BJ8 Brake Pedal Vary Hard to Push Down and Brakes feel like there's no Booster on my BJ8 Austin Healey 27
GTP1960 Drive down memory road. Other Cars 14
AngliaGT MGB When the MGB is Down..... MG 1
KVH General Tech Leak Down Test Triumph 17
aero3113 100 hard top with windshield folded down. Austin Healey 4
N Wire wheel hub removal & suspension tear down Spridgets 3
simon1966 BN1 Strip down well under way Austin Healey 5
SherpaPilot TR6 Engine Will Not Shut-Down Triumph 4
PC the fire down below Spotted 7
S Best Top Down Tune Spridgets 36
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
R Tracking down my dads old Austin Eight Other British Cars 3
