Post-War Other Renown - Idle too fast
HalLucy
Hi Everyone:
I have a '51 Renown that is idling too fast. It has the Solex Type 32 B.IO carb. The fuel pump has been replaced with an electric model (BTW: Does anyone know what the fuel pressure should be?). The idle screw is all the way out and the butterfly looks to be closed. The problem exists at any temperature or choke position. Any ideas?
Thanks!
NutmegCT
Hal - welcome to BCF.
Uncontrolled idle speed is often due to vacuum leak(s).
Do you know how to troubleshoot vacuum issues?
Tom M.
HalLucy
HalLucy
Tom M.
Thanks for the quick reply. I did not realize that this could be a problem with a car this old. How do you suggest that I proceed to diagnose it?
NutmegCT
Other than eyeballing areas around the carburetor, you can spray a mist of water around the manifold and where the carb joins the manifold.
When the engine slows down, you know that's the area where the water was sucked into the manifold.
On my old 1960 Mercedes-Benz 190b, the flange between the intake manifold and carburetor was actually warped, probably due to heat. Air was sucked in throwing the mixture off and speeding up the engine. I replaced the flange, and trued the bottom of the carburetor (lapping). Problem solved.
Hope this helps.
Tom M.
TR3driver
Great Pumpkin - R.I.P
I couldn't find the book just now, but ISTR the Solex downdraft on my Sports 6 only wanted 2-3 psi; just like the later SU carbs. But excess fuel isn't likely to make it idle too fast; instead you'd be seeing black smoke and perhaps a rhythmic miss.
So look for any source of excess air (or fuel/air mixture) getting in. In addition to the usual external leak points, check for a badly worn throttle shaft and, if you can't find anything else, whether the throttle disc fits the bore snugly.
Also might be worth putting a timing light on it, to make sure the timing is reasonable. I've seen several distributors where the advance springs are simply missing, which means it flops to full advance as soon as the engine starts.
HalLucy Wanted Renown Rear Bumper Overriders Triumph Classifieds 0
HalLucy Wanted Renown Dash Triumph Classifieds 0
M Post-War Other OD Switch - 1952 Renown Triumph 2
J Post-War Other Triumph Renown Triumph 13
J Post-War Other Triumph Renown. Triumph 12
J Post-War Other 1951 Triumph Renown. Triumph 7
jdubois Post-War Other Anybody interested in a Renown? Triumph 10
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
drooartz T-Series Can't get idle below 2000 MG 8
Tim Tucker TR4/4A Stromberg 175CD (c.1825) rich above idle Triumph 12
J MGB Idle problem MG 4
G HD8 Idle Adjust Screw Austin Healey 10
B Vacuum at Idle Austin Healey 9
D Lumpy Idle When Hot Austin Healey 2
E MGB MG Idle issues, restart issues solved. MG 4
F TR4/4A idle Triumph 10
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
crispy Idle Speed Variation Austin Healey 19
K TR2/3/3A Slight surging at Idle? Triumph 11
skystryd remind me it's fun. good idle. rough when accelerating Spridgets 6
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
F TR6 Idle change when brake is pressed Triumph 4
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
RAC68 Loose Metal Knocking/Banging Sound during Rough Idle Austin Healey 32
HighAltitudeTR3 TR2/3/3A Mini Pulses at Idle Triumph 6
SherpaPilot TR6 Strombergs with poor idle Triumph 11
C Rough Idle - What to check? Austin Healey 12
Tim Tucker TR4/4A Rich Idle Triumph 14
S Can’t get idle speed below 1300 RPM Austin Healey 28
edkap2002 TR6 Issue of the day......restart and idle after shut down Triumph 21
NutmegCT T-Series MG TD idle speed? MG 12
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
F TR2/3/3A Idle Triumph 10
S TR2/3/3A Carb Idle Question Triumph 6
S Some observations/results to slowly diagnose why my Healey overheats at idle Austin Healey 40
Lutz Kramer Pushing the clutch lets idle speed drop until the engine stalls Austin Healey 18
K TR4/4A Strombergs...wont idle unless choke pulled out? Triumph 7
wkilleffer MGB Air leaks and fast idle speed MG 11
Marla TR4/4A Idle spring? Triumph 7
D 69 E Type High Idle Jaguar 9
K TR2/3/3A Mild street cam and Idle? Triumph 13
Geo Hahn TR4/4A Stumble off Idle with Hot Engine on Hot Days Triumph 4
2billydavies TR2/3/3A very high idle, timing perfect Triumph 7
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
steveg HD8s - getting below 1000 rpm idle Austin Healey 4
RAC68 BJ8: 650 RPM steady Idle at 45 Degree advance??? Austin Healey 26
J MGB Project car done: idle variable MG 2
J SU HD6 - Slow Idle Screw Austin Healey 13
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
RickB MGB Stromberg on my 80 MGB - fast idle this morning MG 6
