General Tech Clutch Release Question
WiscTR
Having finally removed the cover for the shift lever, my next task to ready the core return transmission was to remove the clutch release assembly. Wasn't too difficult but the retaining pin is broken. A cheap enough fix to buy a new hardened pin from Moss but I am wondering about alternatives such as the hydraulic axial release assembly discussed in the 'How to Improve Your TR' book series.
Does anyone have any experience with these? Every vehicle I've ever driven with a clutch has used some type of fork. Never had a problem with any of them until now so maybe it's a solution in search of a problem.
TR4nut
On the past couple of gearboxes I've just drilled for an additional cross bolt through the fork and lever arm. No failures on that yet so I've not looked at other options.
TR3driver
Great Pumpkin - R.I.P
Herman supplies a coaxial slave for his gearbox conversions. Everyone I've talked to has loved it; but I don't know if any if them have had to change seals or the adjustment.
Personally, I'll stick with having them accessible. I've also had that pin break, but I don't expect those seals to last 50 years either. And the reinforcement should solve the pin problem (tho I doubt I will make it another 50 years to find out :smile:
W
WiscTR
Sadly, I suspect that few of here on the forum today will be active fifty years from now, but thanks the internet, a few words of wisdom may persist through future decades :rolleye:
glemon
I cross drilled the fork, grade 8 bolt, plus the pin, hopefully will have no problems. I have a friend with internal slave, it blew up and left him unable to shift 50 miles from home one night.
Not saying they are terrible, just one person's experience, but I guess I personally wouldn't make the change if the goal of added reliability, maybe it does get you a smoother clutch, I don't know.
I suppose you are stuck pulling the tranny if the pin breaks or the hydraulics fail, I am more comfortable putting faith in some hardened steel rather than rubber seals.
charleyf
I use two of the Herman van Den Akker Toyota conversions with the hydraulic axial release bearing. They really spoil me with their quick release / action. I love them.
Charley
titanic
Here is a link to the Buckeye tech. article that explains why the fork pin breaks and how to remedy it-https://www.buckeyetriumphs.org/technical/clutch/ClutchShaft/ClutchShaft.htm
I went the route of machining a pin that is actually supported by both sides of the fork and also added the additional 1/4" bolt.
In my feeble mind, it is just wrong to have hydraulic seals that require removing the trans. to replace.
Berry
T Clutch release bearing question Spridgets 10
K Missing spring clutch release lever Other British Classifieds 1
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
B Clutch Release Bearing Austin Healey 2
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
B MGA Clutch release bearing MG 4
C Clutch Release Bearing Austin Healey 5
Xte New clutch release bearing completely detroyed ... Austin Healey 4
K TR2/3/3A Clutch Release Bearing Triumph 4
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
K TR2/3/3A What's the easiest way to remove the clutch release bearing from the bronze sleeve? Triumph 7
K TR4/4A TR4A Clutch Release bearing Triumph 6
abarth69 1275 Clutch release bearing Spridgets 18
O sprite clutch release Spridgets 1
S TR2/3/3A TR-3 clutch pressure wouldn't release Triumph 3
mountainman TR2/3/3A TR3 Clutch Release bearing Triumph 2
drooartz Clutch release lever bushing Spridgets 12
Thor 1500 clutch release bearing removal -how to do it? Spridgets 4
middleagecrazy Clutch Release Bearing Spridgets 3
M TR2/3/3A TR3 clutch release bearing Triumph 3
T Clutch release bearing.... Spridgets 14
D T-Series MGB GT Clutch Won't Release MG 5
T Slow clutch release Spridgets 6
R6MGS T-Series Clutch Release Bearing MG 5
martx-5 Gearbox Clutch Release Fork Triumph 2
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
