How much advance timing?
DanB
On the wet-sleeve engine, TR2-4A, how much advance is required? I'm talking about vacuum advance and the mechanical advance from the distributor, created by the weights spinning. What is the maximum advance, and at what RPM does it come in fully? When does it start coming in?
I am working on my ignition table for the electronic ignition, and if I had this information it would be quite helpful.
Thanks,
Dan B
S. Charleston, WV
66 TR4AIRS EFI, 80 TR7 DHC
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
DrEntropy MGB Differential with too much lash MG 5
HealeyRick Why 100Ms Cost So Much Austin Healey 14
Rut How much does a 1275 weigh? Spridgets 8
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Healey Nut sooooooooo , how much will it go for ?? Austin Healey 24
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
GTP1960 TR2/3/3A How much is to much fretting? Triumph 10
NutmegCT So many cars! So much has changed! Other Cars 10
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
HealeyRick How Much is that Healey in the Window? Austin Healey 7
TomMull Air Compressors, how much is too much? Restoration & Tools 7
glemon How much paint? Restoration & Tools 8
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
S How much grease for the drive [prop] shaft plunger Austin Healey 3
J How much movement in slave cylinder plunger . Austin Healey 2
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
J Clutch fork free play on BJ8 How Much? Austin Healey 13
F Too much procrastination[maybe long winded] Austin Healey 9
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
richie TR4/4A How much oil is normal.. Triumph 6
drooartz How much fender beading for Bugeye? Spridgets 17
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
Jim_Gruber How much spare fabric in needed to cover panels / dash on a BE. Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
B How Much Pedal? Spridgets 2
J How much to buy an engine block and head? MG 3
johnrip how much gas for winter storage Triumph 17
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
nevets How much brake fluid to fill the system? Austin Healey 3
W 2012 Daytona 200 - missed it by that much British Motorbikes 6
rkep01 How much do you think this will sell for? Spridgets 33
F T-Series How much to pay? Photos of 1955 MG TF 1500 MG 17
F How much of a premium? BJ8 vs. BJ7? Austin Healey 16
CZ_Dave One is too much, a hundred isn't enough MG 4
R Getting Much Closer Triumph 73
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
F Am i Worrying to much??? Spridgets 9
V How much extra engine oil with oil cooler??? Spridgets 5
Got_All_4 TR2/3/3A TR3 leans too much to the right Triumph 10
