carburettor air valve sticking
achtungeveryone
I discovered the air valve was not returning downward on the rear carb. I then for some reason unscrewed the damper and the valve fell down. So I removed some oil out of the damper thinking it may have been over-filled, I guess it may have been over-filled I dunno. I know this is the carb that has the vac leak at the shaft but I have never had the problem with the valve sticking. The PO had the carbs rebuilt but they missed the shaft leak. I am wondering if a throttle shaft leak could cause the air valve to stick. Any ideas? It seems to be running well now so I could have had to much oil in the damper if that's possible.
Achtung
vettedog72
I suggest you examine the rubber diaphragm the attaches the air valve. The diaphragm is responsible for holding the air valve in a concentric position. You may need to replace the diaphragm. Its not likely that the damper is so sticky as to interfere with the drop of the air valve but I guess anything is possible.
Stig
Sounds like a bent damper, swap them front to rear and see if the front carb sticks. The oil level has nothing to do with it, the damper works in one direction.
TR3driver
Great Pumpkin - R.I.P
The only exception might be if the vent hole is closed or plugged somehow. But I agree, a bent damper rod is more likely.
R TR4/4A Carburettor is French for DON'T TOUCH! Triumph 2
N Leaking Carburettor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
T Spitfire Carburettor gasket Triumph 1
magman 100M etched carburettor numbers Austin Healey 4
Simmo Carburettor Metering Needles Triumph 6
bigjones Drilling carburettor Spridgets 11
Tabcon OER carburettor vs. Weber Triumph 5
newmexTR3 TR2/3/3A TR3 Carburettor Heat Shield install Triumph 4
R Carburettor suction chamber cap loose - why? Austin Healey 23
R Carburettor oil MG 32
J Overheating carburettor Jagf Jaguar 10
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
M TR6 Tr6 fresh air vent replacements Triumph 1
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
