TR4/4A Overdrive piston is sticking
tdskip
Hi guys, hope everyone is doing well. So I started to pick the 4A again and have made progress on the transmission issues. The sticking point, literally, at this point is the piston that pulls up the lever to engage the overdrive. The lever moves freely so it is not a case of there being too much friction there, rather it appears that the solenoid itself is not lining up properly and binding when it goes to engage. The electrical system to the overdrive works, the solenoid works, it appears that it is down to the alignment of the solenoid housing in the ass. I am very lightly with dry lubricant greased the pen but that has not helped. What did fix it is that I temporarily loosen the screws that hold the solenoid in place and then you do just fine. It appears that that's late with the room is enough to freeze everything up so it engages properly.
So, anyone else experienced this? Ideas on fixing it? I did think about elongating the holes slightly to allow me more adjustments on how the solenoid unit fits onto the mounting plate, but wanted to check to see if there something else that I should be thinking about before I do that. Thanks!
TR3driver
Great Pumpkin - R.I.P
It seems unlikely to me that alignment is really the problem. That solenoid has to really yank on the lever to get it to move when the accumulator is up to pressure, so it's not likely to be stymied by just a little bit of friction from the plunger not being perfectly aligned.
The things I would look at are:
1) The pull-in coil is not actuating (burned out or contacts inside the top of the solenoid aren't making good contact).
2) High resistance somewhere (eg bad relay contacts) is limiting current through the solenoid.
3) The stop below the plunger is missing, and allowing the plunger to fall down too far.
One perhaps easy test for (1) & (2) is to check how much current the solenoid draws when it doesn't pull the plunger up. It should be close to 20 amps. If it's only around 1 amp, then the pull-in coil is not in circuit. If it is between 1 and 20, then there is a bad connection somewhere. You can also check the voltage between the bullet connector and solenoid housing, with the solenoid energized, to see if the problem is outside the solenoid.
I forget the "drop" measurement for (3) offhand, but it's in the articles on the Buckeye Triumphs site.
T
tdskip
Hi Randall, as always thanks for the help.
Here is what has me stymied with the above - when I left the two screws that mount the solenoid to the mounting plate slightly loose it worked fine. Snapped in and out of OD just fine like that. I have not measured the current but my dash amp gauge shows a big draw when the solenoid is engaged but doesn't pull the lever up. When loosened it reliable engages the overdrive which would not seem to be the case if I had problems in the circuit or with the stop. Yes/no?
Maybe it working when not fully tightened down is coincidental and throwing me off here...
TR3driver
That's close enough for me. Maybe it is misaligned that bad, tho it still seems unlikely to me.
But I would bend the lever to be better aligned, rather than slotting the holes in the solenoid. That is, assuming you pushed the lever hard against the collar and O-ring when you tightened it. (You do have the collar and O-ring between the lever and the OD, right?)
T
tdskip
Oh, you mean all those parts do something? Nope, not there. I bet that has the lever in the wrong place resulting in then location of the solenoid making a difference as it is "compensating" for the lever being in mislocated.
Sound plausible?
Thanks!
TR3driver
Yup. Presactly what I was thinking.
PAUL161
Is the piston and bore clean? No gum in it? Just repaired my 72 MGB with the same problem, gummy piston. PJ
T
tdskip
Good morning, thanks for the idea. I did make sure everything was nice and clean before assembly,good idea however.. Thanks.
Ramdall, I'll get those bits on the assembly and give that a go, once again you have saved me from me. Grin.
T
tdskip
Well, as it turns out the collar and o-ring where actually already installed (professional rebuild who, apparently, did a professional job). What was missing however was the Actuating Lever Stop. When I went to install the collar we discussed above and realized it was already there I noticed the missing stop. I installed one to the spec on the Buckeye Triumph rebuild site and it is working reliably now.
We'll see how she holds up over the next couple of weeks of use.
Thanks guys, and very belated Happy New Year to everyone.
trrdster2000
TDSkip, Thanks for the follow up. It's always good to know what solved a problem.
Wayne
M Healey Overdrive Accumulator Piston using O-Ring Seal Up-date Feedback Austin Healey 4
M Healey Overdrive Upgrade with Larger Piston & Stiffer Springs Pros/Cons? Austin Healey 12
RickPA Overdrive Oil Pressure Austin Healey 8
bighealeysource Leaking Overdrive and Gearbox Drain Plugs Austin Healey 19
71TR6 TR6 Type-J Overdrive identification Triumph 4
T Wanted Working overdrive unit Austin Healey Classifieds 2
D Overdrive Stops Working After Oil Change Austin Healey 26
S TR2/3/3A overdrive does not function Triumph 45
T TR2/3/3A A type overdrive hard engagement Triumph 36
S Overdrive Throttle Switch Austin Healey 4
KVH General Tech Overdrive--Afraid it's Serious Triumph 45
M Overdrive Pressure Test Austin Healey 2
BN6_2197 Gearbox/Overdrive Removal Austin Healey 25
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
Fanch00 Non-Overdrive Benefits? Austin Healey 10
R TR6 J-Type overdrive will not disengage when warm Triumph 8
S Overdrive Relays Austin Healey 2
AUSMHLY Overdrive Buffer Pad Austin Healey 3
L Stuck in Overdrive Austin Healey 10
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
P Overdrive Not Engaging Austin Healey 4
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
John Turney Overdrive Pump Austin Healey 6
S Removing Overdrive Shaft Lever Pin Austin Healey 7
nevets Reversing With Overdrive "On" Austin Healey 8
Healey Nut Overdrive Relay Austin Healey 1
T Clutch or Overdrive Slip Austin Healey 8
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
A TR4/4A TR4 Overdrive Solenoid Triumph 19
H TR4/4A A-type overdrive pump Triumph 4
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
J Transmission and Overdrive Rebuild Austin Healey 6
C Overdrive Failure Austin Healey 18
D TR2/3/3A Overdrive question. Triumph 49
ckeithjordan TR2/3/3A Overdrive Wiring Triumph 5
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
R TR2/3/3A Overdrive wiring installation Triumph 14
BN6_2197 Overdrive engaging with time delay Austin Healey 39
P Broken Overdrive Switch in Gear Knob Austin Healey 14
T Overdrive Problems Austin Healey 18
