sticking speedometer
rajvett
I have a 78 Spitfire with 58,000 actual miles on it. For reasons to envolved to get into I had it stored in my garage for the last 20 years. I recentaly brought it out and after new tires, brakes, clutch slave cylinder and other goodies I thought all was good to go. After 60 miles the speedometer is sticking. 0 to 40 is ok after that it seems to be slow and will not go past 50. When stopping it will drop back to 0. Any good ideas on how to repair it.
Thanks
rajvett
TR4
I took the Speedo housing apart on my TR4 and sprayed the internals clean with WD-40. It works great now. Taking yours apart may identify what is causing it to stick. Could be a bug that crawled in there or spider web.
Check out this website below to download a repair manual. This is what I used to work on my Speedo.
https://home.comcast.net/~rhodes/speedo.html
From the manual:
2) The spindle may not move freely due to the disk binding against an obstruction. In this
case the pointer is stuck in one place or will not rise above a certain level.
M Sticking speedometer needle Triumph 2
K TR2/3/3A Sticking front brakes? Triumph 9
F Choke sticking Austin Healey 22
steveg "Sticking" the brake pedal Austin Healey 3
K TR2/3/3A Oil pressure gauge needle sticking? Triumph 4
T TR2/3/3A Sticking Clutch Triumph 6
vickxxx TR2/3/3A Overdrive solenoid sticking Triumph 6
T throttle sticking? Austin Healey 4
T TR4/4A Overdrive piston is sticking Triumph 9
K TR2/3/3A Oil pressure gauge indicator needle sticking? Triumph 10
B Sticking Starter Pinion Austin Healey 6
J Oilcan spot on fender [IE: not flat, sticking out Triumph 2
J STICKING THROTTLE PLATES Jaguar 7
TR4nut H6 carbs -jets sticking Triumph 15
M Front brakes are sticking Spridgets 33
Kleykamp TR2/3/3A sticking clutch ??? TR3 Triumph 5
M Sticking M/C piston Triumph 7
Got_All_4 TR2/3/3A SU pistons sticking in TR3 Triumph 11
T TR2/3/3A TR3 Sticking Brakes - How come and what to do? Triumph 5
bcbennett TR6 Sticking TR6 throttle Triumph 28
TimK sticking rear brakes Austin Healey 8
KVH TR4/4A Sticking Accelerator or SU Jets: TR4A Triumph 7
mountainman SU Choke sticking! Help Triumph 6
doughairfield Jet Assembly sticking Triumph 6
jtownhealey61 AH 3000 Overdrive - sticking engaged Austin Healey 4
R 1275 timing/ carb pistion sticking Spridgets 3
K Sticking Floats Triumph 12
healeyneil Sticking back brake BJ8 Austin Healey 0
M Bugeye clutch pedal sticking Spridgets 2
R TR2/3/3A TR3a- grose float valves sticking Triumph 6
B Sticking float valves Spridgets 12
Steve P. 1500 Midget; sticking choke Spridgets 6
NickMorgan Sticking horn push Triumph 8
A carburettor air valve sticking Triumph 3
George Zeck Choke is sticking ??? Spridgets 11
RickB Gas pedal sticking - maybe the cable? Spridgets 15
Morris Sticking Shock Spridgets 2
D Sticking Brakes Spridgets 22
X Throttle linkage sticking Spridgets 6
B Is my Thermostat Sticking? MG 9
R Clutch Sticking Problem Austin Healey 4
weewillie sticking butterfly Spridgets 8
TR6oldtimer TR6 TR6 door bottom sticking out Triumph 2
R_Lyle Steering Rack sticking Triumph 4
T Sticking throttle - any ideas? Triumph 8
T Likely cause of throttle sticking open Triumph 5
B Carb Problem - Something's sticking Austin Healey 43
jollyroger Transmission sticking in 1.st Spridgets 3
D Sticking Bonnet Spridgets 4
Webb Sledge TR6 Sticking TR6 Clutch Triumph 15
