throttle sticking?
TomFromStLouis
The engine speed on my BJ8 seems to want to be 4000rpm. Once I get it there it tends to stick and feels a bit like an automatic by pulling me down the road without touching the gas pedal. If I slow down the car in a higher gear the engine speed drops but as soon as I depress the clutch it idles back to 4000 rpm until I quickly tap the gas pedal, which usually releases the problem. Until I accelerate again. I do not consider this dangerous but it sure is irritating and it ruins the mileage I get in the city.
How would you go about determining the actual cause of this? are there some lubrication points that need attention?
Healey Nut
If the car was restored then the bearing on the firewall and the shaft bearings above where the gearbox tunnel fits may be too tight . Does it only stick once the engine gets hot ? It could be expansion from engine heat tightening the firewall/shaft bearings . The ones above the gearbox are a royal PITA to get to with the engine/gearbox in place . If the springs are all in place and good then you may have to ream the shaft bearings to get a little bit more play in them .
J STICKING THROTTLE PLATES Jaguar 7
bcbennett TR6 Sticking TR6 throttle Triumph 28
X Throttle linkage sticking Spridgets 6
T Sticking throttle - any ideas? Triumph 8
T Likely cause of throttle sticking open Triumph 5
B Sticking throttle and choke knob question Spridgets 9
S sticking throttle on BJ7 Austin Healey 2
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 31
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
catfood Throttle return mechanism on the BN1 Austin Healey 4
RickPA Overdrive throttle switch caused meltdown Austin Healey 2
M Throttle pedal problem Austin Healey 8
bighealeysource Strange problem with throttle staying open Austin Healey 6
A Throttle Pedal Height Austin Healey 17
Bob_Spidell Throttle Bushes Austin Healey 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rob Glasgow Overdrive Throttle Switch Austin Healey 9
Rut TR4/4A SU throttle linkage and brackets Triumph 5
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
P Bj8 rhd cable throttle conversion - help Austin Healey 6
TomMull Shortening a throttle cable Q&D with stuff in the shop. Restoration & Tools 5
