TR4/4A SU HS6 throttle spindle size
Djoslyn
I had inherited this car from my uncle around 10 years ago and I know nothing about its history. I'm finally in a place where I can start to work on some of the minor issues it has so on to my question.
My carbs are leaking around the butterfly spindle. I'm trying to determine if they have been rebuilt before or not and if they have stock spindles or oversized spindles. I can't seem to find the stock spindle diameter on these carbs.
The ones currently installed are measuring 0.312in or 5/16.
None of the places to order from specify the diameter other than stock or 0.010 oversized...
Thanks in advance!
Frank Canale
I have a 1960 TR3A with H6 SU carbs. I believe them to be original. I measured non wear areas on both carbs and they both measure .310" You could contact Joe Curto. He has great videos and a good website.
Djoslyn
I did come across his videos earlier today but he doesn't have any specifically up on the HS type carbs. He does mention in the H type bushing installation video about reaming the new bushings to 0.313in, so if the H type carbs use the same diameter shaft as the HS carbs then I'm guessing mine are the stock diameter.
If no one else responds to this then I may contact him directly for the info.
DavidApp
I have a pair of new shafts and they measure 0.310"
Joe does a great job rebuilding the carbs. They come back like new ones.
David
Djoslyn
I took some more careful measurements and the shafts on mine are also 0.310. Also after some more cleaning and having a closer look the bodies have been sleeved already at some point in the past. It looks like a re-sleeving is probably going to be necessary to get the carbs back into shape.
Thanks for the help everyone.
Rut
I always test the shaft to bushing/carb fit by putting the unworn portion of the shaft into the carb and ‘feeling’ if it’s loose or not. I use this method on HS2s, 4s, 6s and 8s and it works well.
Rut
Djoslyn
I may try that first when I decide to pull the carbs and take them apart. There is an almost an imperceptible amount of play in the shaft rights now, which I'm sure is way too much.
I'm thinking about just buying the reaming kit Joe Curto sells and just doing it anyways. :smile:
Rut
I bought the piloted reamer for .010 oversized shafts about 8 years ago along with the reamer for Spridget kingpin bushings and sold both a few years ago because I never rebuilt a carb that needed it. The kingpin reamer was very expensive, never used, and World Wide reams bushings for free when you buy their parts. I’m not saying that you won’t ever run into a carb that needs reaming, but after a few dozen SU rebuilds I’ve yet to find one.
Rut
Djoslyn
Good to know. I'm not surprised to find out that he sells the reamer kit for more than double the price he charges to do the bushing/shaft install service. I'll definitely make sure that I really need new bushings before I go down that path.
Would you recommend starting off with one of the available master carb rebuild kits? or should I just worry about replacing the shafts and gaskets for the time being. The car runs great other than an inconsistent idle due to the vacuum leak caused by the worn shafts and possibly bushings..
STeve 1958
Ten years is long enough to completely ruin the seals in the carbs. The cork will probably fall out in crumbs. Definitely rebuild that first. Then when it's running well you can try some grease on the spindles as a temporary fix to see it that is even a problem.
Djoslyn
I was wondering about the possibility of putting grease on the spindle to temporarily "seal" the vacuum leak. I"ll get a full gasket set, replace the old ones, do some testing and go from there after I see what the results are.
charleyf
I have rebuilt several of the HS6 carbs. On those I found that the spindles seemed to take the wear as opposed to the carb body. I used a rebuild kit from TRF that worked well. Yes the spindles are 5/16". If you remove the spindles you should see the wear on them .
Djoslyn
That was my understanding as well. But it appears that these have already had brass sleeves put in them at some point in the past which has me worried that there could be wear on them as well as the spindle.
titanic
AFIK, all HS6 carbs left the factory with brass bushings. The Moss TR2-4A catalog used to have a good article on re-bushing SU carbs. I think it mentioned .002"-.003" clearance (which seems like a lot) with newly installed bushings&throttle shafts.
Berry
Rut
I’m no expert by any means and my personal approach has always been to buy the rebuild kit and install the throttle shafts first to get a feel for any possible carb body wear. You’ll need the kits anyway for the rebuild and if the bushings are worn to the point of causing a high idle address it with new bushings (my preference) or the oversized shaft.
Rut
Djoslyn
Rut
That is what I'm planning on doing at this point. Thanks for all the help!
charleyf
If the spindles are worn you will see it when they are removed. If they are not worn then one would assume the bushings.
Djoslyn
So I rebuilt the carbs with the SU master rebuild kit. The old spindles were definitely worn but the front carb bushings are worn enough that it still has play and leaks at idle with the new spindles installed. Looks like I'm sending the carb bodies to Joe Curto for new bushings.
Andy Blackley
Berry
I bought a new set of HS6 carbs from Rimmer Brothers and I thought that the throttle shafts "felt" too loose but when I measured the play with a dial indicator it was exactly between .002 and .003. They have brass bushings.
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
G SU HS6 Carburetors Needle Jets Selection Austin Healey 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
F TR4/4A SU HS6 jet initial adjustment jet not flush with bridge Triumph 7
F TR4/4A Replacement air filter for SU HS6 Triumph 6
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Y TR6 SU HS6 question Triumph 1
J TR6 Moss HS6 SU conversion kit question Triumph 4
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
Carlos TR4/4A GROSE-JET or Viton-tip for SU HS6 carbs? Triumph 15
BLong63AH HS6 BJ7 Carb Insulators Austin Healey 5
T TR4/4A HS6 problem Triumph 6
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
TRMark TR4/4A Convert from H6 and log to HS6 and 4A intake Triumph 6
trotti Calling all SU experts - Volvo HS6 Carbs Austin Healey 11
gbtr6 TR6 SU HS6 carb needle questions Triumph 17
KVH General Tech HS6 SU Carbs Triumph 1
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
toysrrus TR2/3/3A HS6 Jet Assy Linkage Request Triumph 4
A BJ7 with HS6 SU Carbs - which needles Austin Healey 1
Simmo TR2/3/3A HS6 Carburettors Triumph 4
charleyf TR4/4A Hs6 carb rebuilding Triumph 8
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
G TR4/4A tr4a hs6 carb Triumph 1
Hap Waldrop SU H6 and HS6 carbs Triumph 9
B TR6 Hitachi HS6 HIF rebuild/TR6 Triumph 1
T SU HS6 tuning - lifting pin question Triumph 11
Lotuswins HS6's on a BJ8 motor Austin Healey 11
H TR6 TR6 HS6 Needle selection Triumph 0
TR4nut TR4/4A TR4A HS6 Factory writeup? Triumph 9
KVH HS6 SU Carbs Triumph 2
K H6 SU carb dome and HS6 carb dome? Triumph 9
T HS6 idle setting Triumph 3
R SU HS6 Carbs overflow leaking........... MG 20
T NLA SU HS6 part request Triumph 10
T Anyone have a spare HS6 pivot bolt Triumph 13
S HS6 Carburetor Austin Healey 16
T One more SU HS6 question Triumph 25
T Float & needle adjustment on SU HS6 - slightly OT Triumph 20
KVH TR4/4A SU-HS6 Carb "Choke" Issue--My TR4A Triumph 8
T TR2/3/3A Will HS6 fit in TR3? Triumph 10
H HS6 Fixed needle centering tips Triumph 1
B Measurements of HS6 Carb MG 12
H TR6 TR6 HS6 Conversion Triumph 6
H HS6 JET identification Triumph 2
H TR6 Volvo HS6 Carbs on a TR6 Triumph 9
H TR6 HS6 RUNNING TOO RICH ON TR6 Triumph 11
H TR6 HS6 for Tr6 -Pics Needed Triumph 1
T TR6 HS6's on a TR6 Triumph 14
chicken is this the correct float for a HS6 carb on a BJ7 Austin Healey 4
