OK guys - what say you on this;
To use the lifting pins or not when adjusting mixture? Lots of writes up say use them, but other say use the screw driver blade method. The lifting pins raise the pistions a LOT more then the screw driver method.
So which one, and how much to raise via the lifting pins?
Tomorrow I'll ask about which oil, what tires, and if I should use DOT5. Grin.
