Hi guys - this is my first time rebuild a set of HS6 carbs and I have two questions I could use some help on.
1) I'm wondering what float bowl height adjustment, if any, is correct or necessary.
2) I'm also concerned that the needle assembly is incorrect. The needle that came with the carbs is on the left, and it the "pin" in the bottom of it moves and appears to allow for better articulation of the gas intake. The new Viton needle from APT Fast has a mushroom bottom to it and is fixed, and does not have any articulation.
BUT (and here is the slightly OT bit) these HS6 are going on the Volvo 122s, and the intake is an upward cast. When the float is held at the same angle as when mounted on the car it appears to correctly. So as long as the needle moves freely in the as-mounted angle I should be OK - right?
Any coaching on either #1 or #2 for me?
