TulsaFred
I need to rebuild my HS2 carbs, but can't find a good source for rebuild instructions. Lots of tuning and some exploded views, but little on specifics of rebuilding.
Anyway, the first problem I run across is the need to replace my needle/seat in the float bowls. It looks like the float must be removed to do this, but the float appears to be held in place by a press fit shaft, which is fairly flimsy and a little corroded. How to remove without damaging the float assembly?
Fred
Fred
