HS4 fixed needle or spring loaded? [which is best]
G
I've got two sets of carbs that need equal amounts of work done to them and I'm trying to figure out which set to build. Both need shafts, SL (spring loaded) needs jets and needles. I'm unsure if the fixed needles need replacing. From wht I've read, the spring loaded type needs the needles replace every 50K or so. That I don't like. I'd rather not have to replace needles if I go to the trouble of tuning them out.
I need to keep a set to convert to injection later on.
Which is the better carb?
spritenut
I have run both fixed and spring loaded HS2s on a couple of Sprites, swapping them out from time to time on the same Sprite.
The spring loaded ones are a whole lot easier to center the jet. They self center.
The fixed needle type seem to be a bit quicker to respond.
My only answer to that is a shorter needle means less travel so it rises faster in the carb thus making it *feel* faster.
Other than that, there is not a whole lot of difference between the 2.
JPSmit
On the other hand I can understand your concern that you will ONLY get 50k miles out of the car before you had to replace the spring needles. That sounds like planned obsolescence to me. :whistle:
(At that rate, I would be about 75 before having to replace the needles)
JPSmit
still 10 years - I don't think the engine itself was designed to last 50k - yours surely isn't
I think that was well stated, the only real reason racers use solid needles most of the time is there were more richer needle choices. No real reason a street car to change the type of needle in almost all cases.
G
Hap wouldn't the fixed ones last longer w/o attention being needed?
I don't see alot of evidence of any of the needles wearing ecessively, and look at a lot of them :smile: Isave needle, and of course buy the richer one for racing, I probably have a couple hundred needles, and measure them frequently at differet station heights and see no real change in their posted measurements. However I often see, where people have filed flat at the top staion to improve idle mixture, that trick has been around forever.
G
Never heard of that, please do explain.
jlaird
LOL, when the engine is at idle the top of the needle valve is deap into the valve thus the top' big end of the needle is controling the fuel. If you file a bit of a flat there you richen the fuel at idle.
davester
...because it's hard to find circular files.
G
If you spin it in a drill chuck and hit it w/ sandpaper, it'll still be round. From what I've read, that's the best method for changing needle profiles. I was wondering if a flat surface had better emultion properties or something other than most files being flat.
jlaird
I don't care what you use or even the shape of the idle portion of the needle. The carb will never know. What ever works for you, file, sandpaper, lathe, what ever.
torque-drive MGB SU HS4 jet height adjustments MG 6
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
bugedd HS4 mixture adjustment help please Spridgets 13
H General Tech SU HS4 Carb Question Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
G Setting mixture on HS4 carbs MG 30
bigjones 1500 - HS4 - improvements Spridgets 3
S Looking for hs4 aud 135r carbs MG 10
G HS4 carb question Spridgets 10
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
H HS4 to HIF inlet manifold question MG 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
T HS4 and HIF4 inter-carb linkages the same? MG 10
T HS4 vs. HIF4 MG 15
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
E HS4 SU carb inlet diameter? MG 15
Jay_Nickell SU HS4 Rehab MG 5
sultanoswing HS4 carb question MG 20
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
A T-Series Switch HS2's for HS4's ??? MG 3
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
