plumbing a single HS4 on the 1500
RobSelina
Okay, with any luck, I'll pull the MG into the garage tonight and swap the carb and finish up the suspension bushings and front springs.
Anyway, on the HS4, I understand it bolts up to the stock manifold, and I'm pretty confident I can work out the throttle linkage, but anything I should know about plumbing it?
I've eliminated the emissions system, run an electric pump, have no return line on the gas tank, but still run vac advance on the dizzy.
Any advice appreciated. Just trying to address any potential issues before I run into them /ubbthreads/images/graemlins/wink.gif
Matthew E. Herd
Rob,
A few quick questions for you, actually ... what sort of springs are you putting up front, and have you managed to get the bushings out from the inside of the lower wishbone? I've tried, disconnecting swaybar, removing springs, and still no luck. I even disconnected the upper trunnion so as to remove everything I could. I simply couldn't press those pins out that hold on the lower wishbone! This could serve as a warning if you haven't done them already, as well as a question to how you did do it, if you're done that part already.
Also, are those wheels Moss brand? If so, what tires are you running and how do they fit? Thanks,
Matt
RobSelina
RobSelina
Matt - I've cheated and started with the rear spring shackle bushings /ubbthreads/images/graemlins/wink.gif Haven't messed with the lower arms yet. As for springs, they're moss' 340lbs springs.
The wheels are the VB minilite replicas. I'm running some 155 goodyear viva2 tires, they're OK, but I intend to get something a little more performance oriented come summer.
Hey Matt! good to see ya again.
those lower pins can be a real pain. on my 79 i ended up beating the living doodoo out of them torched off one side and used a grinder on the other, then called a welder to repair the mess i made. Lots of PB blaster, patience, remove everything else. Those pins want to be driven toward the center of the wishbone, the rearmost needs to go foward and the front pin needs to go to the rear. try to get the heads of the pins un stuck from the mounting flanges. its your only hope. if you can get the exposed bushing removed it can help, trouble is these things tend to become one with the wishbone. Good Luck
mark
RobSelina
RobSelina
okay, i'm loosing interest in replacing those bushings, maybe I'll just do the springs /ubbthreads/images/graemlins/smile.gif
Bugeye58
Rob, plumbing the HS4 should be a piece of cake. I put an AUD135 HS4 on the 1500 Spit engine that I raced with no problem at all. It was originally the front carb on a '65 MGB. Two things I did to make it perform better were to change the float chamber grommet to orient the float chamber to a more vertical position, and change the float cover so the orientation of the float pivot was perpendicular to the cylinder head. This prevents erratic changes in the float level during hard cornering. Both of these items may be unnecessary in your application.
The carb does indeed bolt right up to the ZS manifold, and I simply ran a fuel hose to it, and was good to go.
I can't address the throttle cable or linkage, because I was dealing with a Spit. I was also running a single K&N air filter. No help with the vacuum hookup either, as I wasn't running a distributor.
Hope this helps answer your questions.
Jeff
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
Jim_Gruber Pictures of Clutch Slave Plumbing with Gerard's Kit Spridgets 4
D TR2/3/3A TR3 "Plumbing"? Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
B Compressor plumbing and accessories Restoration & Tools 11
D The more complicated the plumbing..... Other Cars 6
K TR2/3/3A Judson Supercharger Plumbing Setup for TR3??? Triumph 4
fogliner My HS4 plumbing solution MG 13
B brake servo plumbing for BJ7 Austin Healey 8
Gundy HS4 plumbing Spridgets 6
tony barnhill TPI Plumbing Other Cars 8
69MGC Re-plumbing my B roadster MG 5
sparkydave 1500 coolant plumbing Spridgets 5
frankenstang57 Spitfire spitfire fuel line plumbing? Triumph 7
H BJ7 plumbing bracket Austin Healey 2
mperdue SU carb plumbing - overflow MG 11
S Re: the use of plumbing 0-rings for fuel leak Triumph 6
MGTF1250Dave TR2/3/3A TR3 Brake Plumbing Triumph 5
C LCB header with 1500 single carb inlet manifold Spridgets 1
pbraun Single HS2 on an 850 Mini Moke acting odd British Motor Corp 10
shadowfever Single SU on Spridget Spridgets 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
AUSMHLY 65 BJ8 Front Single Lamps Austin Healey 35
steveg Switching multi-wire wideband O2 sensors between single gauge Austin Healey 11
K WTD Single SU Manifold for AH Sprite Spridgets 0
R 1275 engine with SU HIF single carb Spridgets 9
SherpaPilot TR6 Single Spark Plug is Burned Triumph 12
drooartz Single stage vs base/clear Spridgets 29
M TR2/3/3A Single brake light modifcation Triumph 2
W Single Minator wheel available Spridgets 3
N DCOE double vs. single choke theory Spridgets 11
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
Scott_Hower 1500 single rail gearbox rebuild? Triumph 7
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T Wedge The Wedge Shop Single Turbo TR7V8 build Triumph 3
T building a single tower Sprite storage lift? Spridgets 21
J Bugeye single piece top frame same as two-piece? Spridgets 4
B Spitfire big bearing snap rings on Spit single rail Triumph 0
B Spitfire That Spitfire single rail gearbox again Triumph 2
N Convert BJ8 exhaust to single silencer Austin Healey 6
B Spitfire Aftermarket synchros 1500 Spit single rail Triumph 2
G Spitfire Anyome here running a single DCOE on a Spit? Triumph 0
G Spitfire Anyone have a single DCOE mainfold for a 1500 Spit Triumph 0
bigjones Single HS4 on a 1500 Spridgets 25
Stinger Stag TR4A Paint BRG #25 Single Stage or Base Coat Clear Triumph 13
L Two screw or single bolt side view mirrors? Austin Healey 8
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
