TR6 1973 TR6 emissions plumbing
sundown
I went with a tee I connected 3 hoses 1 to the valve cover and 1 to each carb.I capped off the side of the banjo bolt going to the canister. I still want to vent the gas tank line to the canister can I leave the other 2 outlets on the canister open or do they need to be sealed off. Thanks for any input
poolboy
Either way..There should be a nipple on the bottom of the CC that was for a U-shaped hose that went to the Anti Run-on Valve.
Since you are not utilizing the ARV, fresh air will enter the CC thru that opening. So, you can cap the top nipples if you leave the bottom one open.
In other words you do not want the gas tank vent connected to an otherwise completely sealed container otherwise a vacuum will form in the gas tank as the fuel level drops, defeating the purpose of a vent.
sundown
sundown
Thanks poolboy, If I understand this right I can leave the 2 nipples on top of the cc not capped it would have the same effect as taking the u-shaped hose off the arv?
poolboy
https://www.mv.com/ipusers/last/emissions/page_52.html
Even though you have removed the vacuum to the ARV disabling it's function, there will still be fresh air getting into the CC thru the ARV (illustrated on the left)..except during that brief interval when there is still residual oil pressure after you turned the ignition key to off (on the right minus the vacuum)...that is if you still have the ARV electrically alive.
If you smell gas from the gas tank vent coming out of those top nipples, you could go ahead and cap them...open or capped, there won't be any affect on the engine.
sundown
sundown
Thanks again poolboy for all your help.
I have some more questions the carbs and crankcase hoses are hooked up together the cc is still wired up as well as the ARV the only connection to it now is the gas tank vent line. I did not seal off the other 2 nipples on the cc. I want to check out the vacuum readings (just purchased a tester) where should I hook up the vacuum fitting on the banjo bolt do I disconnect the hose going to the ARV?
poolboy
That's right. That nipple should be just the right size for the vacuum gauge's tube.
But didn't you write previously in post #1 that you removed that hose on the banjo fitting going to the ARV and capped the nipple on the banjo ?
sundown TR6 1973 TR6 emissions plumbing Triumph 1
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
