TR6 1973 TR6 Rear Brake Operation Questions
Jerryny
Good Morning all,
I'm trying to understand how the rear brakes on my 1973 TR6 work.
My understanding is: When you press the brake pedal brake fluid is sent to the left and right wheel cylinders. The wheel cylinder then pushes the front brake shoe against the drum. What I don't understand is: What is supposed to push the rear shoe against the drum? Probably a dumb question but watching it in operation I don't see the rear show moving outward. Is this normal? All help is appreciated
Thank You
Jerry
Rod-H
Bronze
Not a dumb question at all. The rear brakes are semi-free floating (for lack of a better term).
Simplified: When you press the brake pedal the wheel cylinder expands to force the leading brake shoe to contact the brake drum. Then after the front shoe makes contact, the wheel cylinder shifts as pressure is applied to cause the rear shoe to come in contact with the drum. Both brake shoes in contact. When you release, the springs and brake drum rotation cause everything to return to original position.
Rod
Madflyer
Jerry; If you are getting no movement to rear shoes there is a splitter after master cyl for brake failed. This will need to be reset by bleeding front brakes to move piston to open rear brake line. Madflyer
Andrew Mace
What you describe is the PDWA (Pressure Differential Warning Actuator). Its only purpose is to activate a warning lamp when there is a pressure difference between front and rear circuits. It does not shut off anything!
J
Jerryny
Rod
Thank you very much
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
