TR6 1973 TR6 hydraulics
sundown
Things went from great to I can't believe it. Poolboy helped me thru the emissions plumbing took it out for a nice ride ran great. I get up this morning ready for a early morning cruise. I start her up push the clutch pedal in right to the floor check the reservoir empty? I need to put some fluid in to see where it blew out I always use Castrols GT LMA which I can find without ordering it. Is there a brand that I can get without destroying the rubber seals. Thanks
poolboy
Wherever it's leaking, I'd recommend rebuilding both the master and the slave..if they are not pitted and because of that can be rebuilt.
Unless you are using Silicone (purple in color) you can use NAPA brand DOT3 or Valvoline DOT 3-4. without problems..at least that's my experience.
One thing that often brings questions on the Forum is "SYNTHETIC" or "FULLY SYNTHETIC" on the label.
No problem.. but not to be confused with "Silicone".
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
