TR6 1973 tr6
sundown
Thanks members for answering some of the issues I am having. I'm pretty green on the understanding of this really cool car. I have another one for the experts I started the engine and using a timing light adjusted the timing to about 17degrees btdc when I first tried I could not even see the numbers on the pulley is this a good setting it runs pretty good. Also I notice the number 6 plug has some engine oil seeping out onto the block could it be a bad spark plug gasket the other plugs are fine. Thanks
poolboy
You should try to have a different title for each topic..otherwise it appears to be a duplicate of your other "73tr6"
Something like "Ignition Timing question about 73 TR6"
I have my own idea about using the damper marks to set the ignition timing..I don't. Instead I use a Vacuum Gauge connected to the banjo fitting on the intake manifold and use the manifold vacuum as an indication of the quality of the combustion.
Want More ?
https://automotivemileposts.com/garage/v2n8.html
sundown
sundown
Thanks poolboy about the topic issue still feeling out the site. I do not have access to a vacuum gauge. Thanks
TR3driver
Great Pumpkin - R.I.P
Or about half that, if you have a Harbor Freight nearby. https://www.harborfreight.com/fuel-pump-and-vacuum-tester-93547.html They sometimes have them on sale for $9.99.
17 seems a bit much, but the important thing is that the engine never knocks (aka detonates, pings, etc) under load. The idle timing is deliberately a bit slow (even without the vacuum retard), for easier starting etc; so the factory advance curve moves quickly at low rpm to bring the timing up to optimum at medium and higher rpm. So if you set for best idle (whether by ear or by vacuum gauge), the timing may be over-advanced at higher rpm; which might lead to knock (or not, depending on a lot of factors like fuel, temperature, engine condition and so on).
This is typical pre-ignition damage, although in this case it was caused by too much oil burning (oil has a really low octane) rather than too much spark advance
So my suggestion would be to stick with the factory recommendation of 10 BTDC (assuming the vacuum retard is disabled or not working).
The oil you are seeing is most likely leaking somewhere else (like maybe the rocker cover gasket) and just collecting around the plug. Unless the tip of the plug is covered in oily black deposits (from burning oil), the oil is not likely to be coming from the cylinder. And even if it was burning oil that bad, you wouldn't be likely to see liquid oil on the outside of the plug unless the cylinder was not running at all.
sundown
sundown
Thanks guys a lot of great info.Randall I feel a little more at ease now about the oil seepage near the plug. Sundown
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 - broken choke cable Triumph 6
M TR6 1973 TR6 Coolant Type? Triumph 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
