TR6 1973 TR6 Coolant Type?
M
MartyN
What coolant type would you recommend for a 1973 TR6. If you do not mind please specify the exact brand. We are new to enjoying our TR6 and want to make sure that we don’t mess things up! Thank you in advance!!
NutmegCT
Hi Marty - assuming yours is a stock '73, and not knowing where you live, I'd say
Any commercial OAT or ethylene glycol antifreeze, diluted according to your climate zone, should be fine. Prestone, etc.
Add coolant directly into radiator (fill to seat of neck). Then drive check again, and when cool top it off if needed. I'm pretty sure that your year car should have a 13 psi cap; if it’s old you might want to replace it.
Tom M.
poolboy
Prestone, but that's just a brand preference, just like Kendall is my current motor oil preference and Chevron or Shell for gasoline
Madflyer
I live in Reno Nevada cold winter warm summers a 50/50 mix works well here. Some also add water pump lube and or Wetter Water in hot areas. As for the cap could be very important and add a new thermostat some say 165 deg. I use 185 deg for better heat in winter. Some will say a 185 deg is to high the point is to keep the water in the radiator longer. The best way to tell is start with a cold motor and start with cap off you should see NO water movement until steam comes out. You will need to top of after a mile or two. and have a recovery bottle from cap to bottle with bottle 1/2 full.
Think of it this way; if you water is say 165deg your block is much hotter than 165, and that is at the front of the block where as the back can be even hotter. your block and motor oil could be as high as 300 deg. And last what ever your temp. gauge reads check with an outside reading say a meat thermometer in the water or hand held temp reading tool.
I also have a 1973 TR6
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
M TR6 1973 TR6 - broken choke cable Triumph 6
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
J TR6 1973 TR6 Rear Brake Operation Questions Triumph 4
M Wanted Tr6 1973 Triumph Classifieds 2
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
sundown TR6 1973 Tr6 alternator Triumph 6
B For Sale 1973 tr6 Triumph Classifieds 0
GBRandy TR6 1973 TR6 Rear Frame / Body Bushings Triumph 3
W TR6 1972 or 1973 TR6 Triumph 9
sundown TR6 1973 TR6 plugs Triumph 4
sundown TR6 1973 TR6 mossmotors sport exhaust system Triumph 6
sundown TR6 1973 TR6 blow by or leak? Triumph 6
sundown TR6 1973 TR6 flasher question Triumph 6
sundown TR6 1973 tr6 Triumph 3
sundown TR6 1973 TR6 Heater Triumph 1
sundown TR6 1973 TR6 seats Triumph 1
sundown TR6 1973 TR6 vacuum reading Triumph 2
sundown TR6 1973 TR6 oil between the head and engine block? Triumph 11
sundown TR6 1973 TR6 carb/ TBV Triumph 5
sundown TR6 1973 TR6 bypass valve Triumph 1
sundown TR6 1973 TR6 fuel pump Triumph 4
sundown TR6 1973 TR6 ZS carb mixture Triumph 2
sundown TR6 1973 TR6 door check straps Triumph 3
sundown TR6 1973 TR6 hydraulics Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 1
sundown TR6 1973 TR6 emissions plumbing Triumph 8
sundown TR6 1973 TR6 timing light Triumph 3
sundown TR6 1973 TR6 vacuum leaks Triumph 1
sundown TR6 1973 TR6 brake booster hose Triumph 7
sundown TR6 1973 TR6 charcoal canister Triumph 6
B TR6 1973 tr6 water pump Triumph 4
sundown TR6 1973 TR6 strombergs Triumph 3
sundown TR6 1973 tr6 Triumph 8
sundown TR6 1973 tr6 Triumph 5
sundown TR6 1973 tr6 Triumph 0
sundown TR6 1973 tr6 oil pressure light Triumph 3
sundown TR6 1973 TR6 flasher unit Triumph 1
sundown TR6 1973 tr6 wiring Triumph 21
jerrybny TR6 1973 TR6 Seat Covers Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
JoeC TR6 1973 TR6 parts car Triumph 2
jerrybny TR6 1973 TR6 Front License Plate Bracket Triumph 1
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
S Stag 1973 Triumph Stag Triumph 2
R TR6 1973 Final drive issues Triumph 5
