HS4 vs. HIF4
tony barnhill
Great Pumpkin - R.I.P
I personally like HIF-4's...am in the middle of rebuilding a set of HS-4's right now but its my only car that I've not converted over to HIF's
Platinum
<*RASPBERRIES*>! /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
tony barnhill
I'm not a real good carb guy but I like them because of the integrated fuel bowl..the guy who can answer that question is Doc
Right now I've got a set of HS-4's completely apart & there seems to be more possibilities of problems with them (centering jet, etc.)
Platinum
Again, duelling posts! /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
Platinum
Where's that <squelch> button?!?!
tony barnhill
Whadda ya think, Doc - personal preference only difference in them?
Platinum
Kinda-sorta. I like the hard mounted needles and the bowl lids for convenience, the HIF's not so much. The floats & needles/seats in the HIF's are more hassle to service. Needles in the HIF's are intermittantly rubbing the jet at changes in RPM. It takes a long time for that to be detrimental (hogs out the jet orifice to an oval) but it kinda seems 'funny' to me. It also makes an odd kind of liquid/vapour column appear at the inboard side of the needle, a laminar flow issue. Not quite as efficient as the older, hard centered piston/needle combo. The "package" of the HIF's is neater looking, the flow characteristics are nearly identical, so really it's down to what you want/like, yup. If it were a car for a track career it'd be the older ones, if a street machine, it would be less an issue.
tony barnhill
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If it were a car for a track career it'd be the older ones[/QUOTE]
HS-6's for track car - with insulated fuel bowls.
BOXoROCKS
I'm sure no expert,but boy I got an opinion on these, I dont like HIF carbs. A pain to adjust the float,and more prone to flooding.They are just a more complicated, expensive carb,and every set I have ever had caused way to much trouble.
Just noticed,is that 66 alfa an "alfa romeo giulia sprint GT veloce" gotta love the Italians.
Platinum
Pick yer "drivers"!
LBC's are my first choice, the eye-tie coupes are a close second. Very close. They're spectacular as trustworthy steeds.
G
The problem of the HIF float adjustment is overrated. Do it right once and you're done. I find the HS far harder to adjust and far more prone to fuel leakage from the jet tube when the tube developes a crack
tony barnhill
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]far more prone to fuel leakage from the jet tube when the tube developes a crack [/QUOTE]
which they will from the constant up & down movement - they'll leak right at the fuel bowl.
I build a buttload of SU carbs, they are both good carbs and fairly trouble free when serviced and rebuilt with the right parts and by someone who understand these very simple carbs. The HIF4 is easier to rebuild, the HS4s are easier to live with once on the car, for that reason alone, if I'm starting from scratch, I lean towards the HS4s.
T HS4 and HIF4 inter-carb linkages the same? MG 10
torque-drive MGB SU HS4 jet height adjustments MG 6
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
bugedd HS4 mixture adjustment help please Spridgets 13
H General Tech SU HS4 Carb Question Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
G Setting mixture on HS4 carbs MG 30
bigjones 1500 - HS4 - improvements Spridgets 3
S Looking for hs4 aud 135r carbs MG 10
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
G HS4 carb question Spridgets 10
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
H HS4 to HIF inlet manifold question MG 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
E HS4 SU carb inlet diameter? MG 15
Jay_Nickell SU HS4 Rehab MG 5
sultanoswing HS4 carb question MG 20
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
A T-Series Switch HS2's for HS4's ??? MG 3
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
