HS4 to HIF inlet manifold question
hottvr
I'm putting together a set of HIF's that came without an inlet manifold. I have 2 from HS4's. Can I use one from HS4 FOR THE HIF.
Thanks
Rick
GTsRFine
As far as the spacing and bolting-up requirements go, they are interchangeable.
Other considerations are the threaded fittings - are they the appropriate size for your anti-pollution equipment (if used). Also the exhaust manifold "ears" should be the same thickness as the intake manifold "ears" or you will need to shim them to prevent vacuum leaks. I think there is about an 1/8" difference between the HS4 and HIF4 manifold ear thickness. These are minor considerations though, you should be able to create work-arounds.
Bob Claffie
I swapped from HIF to HS4's without any fitting problems. Only glitch is the connecting shaft between the carbs is a different length. The HS4's requiring a longer shaft than the HIF's. Bob
torque-drive MGB SU HS4 jet height adjustments MG 6
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
bugedd HS4 mixture adjustment help please Spridgets 13
H General Tech SU HS4 Carb Question Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
G Setting mixture on HS4 carbs MG 30
bigjones 1500 - HS4 - improvements Spridgets 3
S Looking for hs4 aud 135r carbs MG 10
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
G HS4 carb question Spridgets 10
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
T HS4 and HIF4 inter-carb linkages the same? MG 10
T HS4 vs. HIF4 MG 15
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
E HS4 SU carb inlet diameter? MG 15
Jay_Nickell SU HS4 Rehab MG 5
sultanoswing HS4 carb question MG 20
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
A T-Series Switch HS2's for HS4's ??? MG 3
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
