anyone have .... [now HS4 linkage problem]
RobSelina
Trying to figure out the HS4 swap on my 1500 and a pic of the throttle and choke linkage would really help out.
thanks,
rob
BOXoROCKS
Re: anyone have a pick of a single HS4 linkage?
I dont know how to post a pix but I did the same thing. I used the rear carb.Use your old and new link combos to get what you want.
RobSelina
RobSelina
I guess the one I have would be the front carb, that may be why I'm having issues. Check out this pic:
The choke is easy enough but the throttle is getting the best of me. I can't see any way to adapt the ZS linkage and in the workshop manual it looks like the throttle linkage was attached to the intake on the UK models.
Anyone? About the only thing that comes to mind is to fab a bracket that attaches to the dashpot cover bolts so that I can have have the upper linkage mounting point like on the ZS...
Any insight on this would be appreciated....
RobSelina
RobSelina
update:
- I'm starting to question wheter this carb is actually an HS4. I'm thinking it's an HIF4 since it won't bolt up to the intake manifold....back to searching for a used carb /ubbthreads/images/graemlins/frown.gif
- I reinstalled the ZS and retuned it. The damper had NO oil, which would explain why it was running so poorly. It appears to be slowly leaking down the sides of the piston...It's running well now but I won't be able to try her out until a replacement rear shackle arrives from Moss tomorrow (the nuts were siezed snapped off during removal)
BOXoROCKS
Thats a HS4 not HIF, been awhile since I did mine but I am sure I had to drill and tap the manifold and use a spacer block.
Mark Jones
Rob;
Go to this web site to see pictures of the HS4 swap. There are some good pictures of what the linkage should look like. Also check Rimmer Bros web site for more diagrams of the setup. If you have any further questions, or need other pictures email me; I did the conversion on my Spitfire a couple years ago.
Basil Anyone remember Dave Russell? Austin Healey 9
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
Celtic 77 Anyone recall Hobo Hill in New York State? Racing 0
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
JPSmit Gear reduction starters anyone? Restoration & Tools 5
L Can anyone tell me what car this is from please? Other Cars 0
DrEntropy Show this to anyone under 40... Restoration & Tools 9
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
D Can anyone identify this vintage car? Other British Cars 17
T Can anyone identify this bumper Spridgets 5
AngliaGT Morgans - Anyone Heard From John Sheally lately? Other British Cars 13
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
K TR2/3/3A Anyone remember the "rattling gear shift" fix? Triumph 8
roscoe Comments, anyone? Austin Healey 3
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Anyone have spark advance data for Piper camshafts? Spridgets 1
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
T Powertrain locked up three times whilst driving today - anyone have thoughts? Spridgets 15
S TR2/3/3A Anyone care to share their bondo applying techniques Triumph 35
DrEntropy MGB Clevis pins, anyone? MG 3
69MGC Wanted Anyone know this guy? MG Classifieds 2
B Does anyone still make or sell a quality condenser? Austin Healey 14
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
K Anyone racing a TR3? Racing 5
S General TR Can Anyone identify this TR Triumph 3
C Anyone know where to get one of these? Austin Healey 6
Grantura_MKI T-Series MG TD anyone? MG 5
HealeyRick Why Would Anyone Butcher a Healey with a V8? Austin Healey 26
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
K TR2/3/3A Anyone heard of an oil additive called 'Molyslip E" ? Triumph 5
Basil SS100 anyone? Jaguar 5
Jim_Gruber Recovering Dashboard - Anyone tried this approach? Spridgets 4
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
R General TR Anyone going to TRA in North Georgia? Triumph 0
R Wanted Anyone have one of these? Triumph Classifieds 6
mt10flyer TR2/3/3A Anyone race prepped a TR3? Triumph 3
Rut TR4/4A Sorry Top anyone? Triumph 0
Got_All_4 General TR Anyone know where to get one of these? Triumph 5
AngliaGT Anyone in Charlotte,NC That Could Check Out a Truck for Me? Other Cars 0
Gliderman8 TR2/3/3A A nice ORIGINAL TR3A resto project if anyone is looking Triumph 3
Got_All_4 TR2/3/3A Has anyone installed one of these slack limiting plates Triumph 4
