HS4 SU carb inlet diameter?
eeeaooo
I've got a pair of Japanese SU HS4's (38mm/1.5") made by Hitachi (made for old Datsuns), of which some parts are compatible with the British SU's. I'd like to get a pair of velocity stacks/air horns for them, but I don't know if the inlet diameter matches up. The Hitachi SU's inlet diameter measures 35.8 mm....not to be confused with the butterfly or throat diameter. Can anyone tell me the INLET diameter of the British HS4 SU? This would also correspond to the velocity stack final diameter. -Thanks
Nunyas
*IF* I'm not mistaken the British SU HS4 should be a 1.5" design making it compatible with your Nippon constructed piece.
Platinum
BRB.... I'll check.
Measures 1.384". And lest you think me a Philistine:
HTH!!!
E
eeeaooo
I know that K/N filters mount the same, but the filter housings aren't made to close tolerances anyway. The velocity stack should be fairly precise (I would think). By the way, if anyone is interested, I HIGHLY recommend adding a bung in your exhaust just below the manifold/header flange, so you can mount an O2 sensor, make up a wiring harness, and add a digital air/fuel gauge. Before I got the gauge I could tune the SU pair to within 1/8 of a turn if I'm lucky. Now I can tune them to within about 10 degrees of a turn. My gas mileage has gone way up, too!
Platinum
...and ~yes~ that's my kitchen countertop that stuff is on...
Hey doc is that a toaster oven, or a Ronco setitandforgetit thingy?
Nunyas
huh.... a "high tech" method to get the proper tune... who'd a thought... /ubbthreads/images/graemlins/smile.gif
E
eeeaooo
Thanks Dr. Entropy! That converts to 35.154mm. One question though....did you measure using the calipers with points on the ends, or cylinders? If you measured with cylinders, then the actual diameter is probably a hair bigger since there's a gap between the square-edged caliper cylinder and the round wall that's not acounted for...are the cylinders on your calipers about 1/4" dia? ...because that would work perfectly dimansionally. Yippie! I can finally get air horns!!!
Platinum
HUH?? I used the pin gauge and the mic's inna shot. NO calipers involved... The deviation would be th' FUZZ of corrosion in the carb bore: they've been BURIED inna shed for a few years. I had to risk life and limb for this data on a timely basis and THIS is the thanks I get?!?!? /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/jester.gif /ubbthreads/images/graemlins/thirsty.gif
Platinum
...It's a toaster oven, Kenny.
/ubbthreads/images/graemlins/grin.gif
E
eeeaooo
Thanks!
I've got some extra arms and two left legs laying around in my shed if you wnt them. Just don't ask anything about them.
Platinum
"Anonymous donor" tags?
...I'll have 'em.
"...OI!! Wha's wid da LIMP?"
hehehehehehe
Platinum
Them's th' new ~calibrated~ C-clamps, Jeff.
I gotta find and post an Alfa Romeo "Factory Bulletin"....
"New rules for employees:
1) The practice of using micrometers as C-clamps will cease immediately.
2) Duelling with forklifts is now STRICTLY prohibited."
Can't remember the rest but I'll dig that out.
Nunyas
[ QUOTE ]
[/ QUOTE ]
ROFL!!! /ubbthreads/images/graemlins/lol.gif
that reminds me, I had a duel with a fork-lift once, just me and the lift. I lost with a broken foot, 21 stitches, and four 12 inch pins sticking out the end of said foot... /ubbthreads/images/graemlins/eek.gif not a very fun time.
H General Tech SU HS4 Carb Question Triumph 5
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
G HS4 carb question Spridgets 10
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
Atrus Carb velocity stacks - are these HS2 or HS4? Spridgets 2
T HS4 and HIF4 inter-carb linkages the same? MG 10
wkilleffer MGB HS4 carb question- 18GK engine, 1974 MGB [long] MG 6
sultanoswing HS4 carb question MG 20
torque-drive MGB SU HS4 jet height adjustments MG 6
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
bugedd HS4 mixture adjustment help please Spridgets 13
dklawson Hs4 Float Bowl Failure Spridgets 11
RichBall HS2 and HS4 measurment Spridgets 7
bigjones HS4 needle mystery MG 15
mikecyc72usa Spitfire Spitfire 1500, SU HS4 major issue Triumph 14
fogliner My HS4 plumbing solution MG 13
G Setting mixture on HS4 carbs MG 30
bigjones 1500 - HS4 - improvements Spridgets 3
S Looking for hs4 aud 135r carbs MG 10
G HS4 fixed needle or spring loaded? [which is best] Spridgets 15
Gundy HS4 plumbing Spridgets 6
bigjones HS4 - quick question MG 6
bigjones HS4 - 1500 - slight problem Spridgets 24
JPSmit Quick HS4 Question MG 2
bcbug Installing a HS4 on a 76 Midget Spridgets 12
bigjones Single HS4 on a 1500 Spridgets 25
dklawson Single HS4 Conversion Troubleshooting Triumph 6
C Single HS4 vs pair of HS2 on a 1275? Spridgets 21
JPSmit HS4 needle question MG 2
JPSmit SU HS4 question MG 3
dklawson Spitfire ZS Stromberg vs HS4 SU on 1300 Spitfire? Triumph 11
H HS4 to HIF inlet manifold question MG 2
don62 SU HS4 head jets adjustment MG 12
T Spitfire Spitfire HS4 help Triumph 11
T HS4 vs. HIF4 MG 15
Atrus 1275 intake manifolds [Weber, HS4, custom] Spridgets 6
Atrus [2] HS2 vs [1] HS4 Spridgets 10
budk1953 Need a Pic of HS4's Spridgets 8
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
RobSelina Air filter housing for HS4 [also need tuning help] Spridgets 21
mgblue79 1500 Midget HS4 conversion Spridgets 8
KLUTZ HS4 Spring count. MG 1
Jay_Nickell SU HS4 Rehab MG 5
RobSelina anyone have .... [now HS4 linkage problem] Spridgets 5
RobSelina plumbing a single HS4 on the 1500 Spridgets 5
mylillooker SU HS4's "vs" Weber 32/36 Spridgets 5
P MGB Choke on SU-HS4 1971 MGB MG 4
A T-Series Switch HS2's for HS4's ??? MG 3
RobSelina Single SU HS4 swap on a 1500 Spridgets 2
