I'm putting an HS4 carb on my Midget. It was the rear carb off an MGB. On top of the float, there are two fuel lines. Currently, the higher one points at the engine while the lower one points at the fender. (I presume this is the correct alignment)
Which is fuel in? And should I cap the fuel out as I'm only using one carb?
thanks all
thanks all
