SU H2 Carb - Needle Removal & Replacement
mxp01
All:
I have a pair of HS2 carbs. I purchased a rebuild kit from British Parts Northwest (highly recommend) and it included a replacement needle that has a flange near the end (not the tip end0. I loosened and removed the set screw from the side of the piston, but the needle did not slide out. The needle moves in slightly against a spring, but won't come free. Can someone explain to me the method for removing this type needle?
Thanks,
Mike
SD Bugeye
What you have is a self centering needle it should just pull out
along with the greyish barrel that the side screw was against.
R T-Series SU carb needle question MG 1
HighAltitudeTR3 TR2/3/3A Carb Needle Stamp... Triumph 1
gbtr6 TR6 SU HS6 carb needle questions Triumph 17
Zitch Needle info on a SU H6 Carb Triumph 5
K TR4/4A SU carb Lean [SL] needle for TR3/4A? Triumph 9
D Wedge TR7 Needle in Spitfire Carb! Triumph 1
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
martx-5 SU carb needle selection program. Triumph 0
W Carb & Needle ZS CD carb Triumph 11
mrsprite Carb needle questions [long] Spridgets 11
M Carb Needle Info Austin Healey 8
M zs carb meetering needle position? MG 5
Thor SU Carb Needle Selection Triumph 3
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
