John_Progess
The manual says there should be .006" to .010" end float for the counter shaft gear. I mentioned in an earlier post that I had a terrible time getting the counter shaft gear out of the box because the rear bearing fouled the thrust washer and jammed the gear in the case. I have installed new counter shaft bearings and new thrust washers but now I only have about .001" end float clearance if any at all. With the counter shaft and thrust washers installed in the case it actually feels like it is dragging slightly as I spin the counter shaft gear. Moss only lists one choice for each of the thrust washers so do I need to dress down the bosses in the case to get my .006" float or what have other people done to solve this problem? Thanks for your help and have a good day!
John
John
