grant tr4a
Member
Probably a very simple question, but I want to be sure. I am trying to lean out the mixture a little, the plugs seem to blacken up at idle. When I run on the road they clean up. So my question is which way do I turn the mixture adjusting screw. Is it counterclockwise looking down on top of the carb. I have books that tell wich way to turn, but they do not say if you look from the top down or from the bottom up? Grant
