H6 SU carb dome and HS6 carb dome?
AEW
I'm supposing you already have checked the Moss catalog and seen the parts are different....370-850 H6 and 371-600 HS6.
Now if you want a 59TR that will start in Winnipeg today you should look at converting over to a nice old Bosch CIS fuel injection, or a heated garage ! :wink:
ed
K
karls59tr
Bronze
Actually I was wondering if the chrome covers that fit over the SU domes were of different sizes. Saw a set on ebay. No way I'd drive my Tr in the winter here....too much salt on the roads.
AEW
Ah... Well couldn't the ebay seller tell you the inside dimensions? Again supposing.... you have H6 examples to then measure and compare. If not, I can at least do that for you. Can't say about the TR4a carbs since I have none of those. But someone else on the forum may if you pose it as a question.
regards
ed
(btw, I really like my FI idea)
K
karls59tr
Bronze
Good idea. I'll ask the seller. My winter car is an 86 Saab 900S with fuel injection....fires right up in our winters. :smile: I see your located in Oregon. ...any wrecking yards out that way that still have old britsh cars on them or are those days long gone?
eschneider
I *think* the difference is that the H6 uses brass-capped dampers (vent in the dome / vacuum chamber) and the HS6 uses plastic-capped dampers(vent in the plastic cap). As long as you match the dampers to the dome, you should be OK.
Pretty sure that's the trick, but I'd await confirmation from Randall or Doc Entropy.....
DNK
Must be slow at Acme presently. Haps answering a lot of questions :laugh:
K
karls59tr
Bronze
You know...I was wondering what is the best way to polish the domes? Do you need a buffing wheel or special paste etc?
TR3driver
Great Pumpkin - R.I.P
They make the job easier, but neither is absolutely required. Check YouTube for lots of videos and advice. I picked up an assortment of buffs & compounds at HF for $20 or so (tho that was a few years back).
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
R TR2/3/3A Carb throttle return spring tension Triumph 2
drooartz MGB Troubleshooting Mikune carb MG 33
