ummm.... the outer sleeve (bushing, bearing, guide) should be tightened with the jet in the fully flush position (business end flush with the top of the sleeve), and the needle/piston/chamber assembled. This allows jet "centering" as the top nut (the one securing the sleeve in the body) is tightened. The piston assembly should rise and fall easily, a "thunk" heard when it is dropped to "zero" position. Once this is achieved, with the jet top flush with the 'bridge', lower the jet by 12 'flats' on the lower (sprung) nut. That should be a very close setting from which to begin tuning it.
