one more time.....mirrors!
maxwedge5281
not ready to start drilling holes but I am interested in using a mirror that mounts in the side curtain hole on a 59 bn6. I see that moss has a mirror but I am not particularly fond of the rounded rectangular shape. any other suppliers that supply such but with a more rounded shape. pics are appreciated if you have a suggestion! thanks in advance for any help.
steveg
You can use the regular Lucas-style mirrors Moss sells. I'm running a Raydyot mirror, but here's my old Moss stem in the sidescreen hole.
RDKeysor
Bronze
I have a pair, L & R, branded as Harley Davidson. These came on my BN7 mounted in the forward side curtain holes, with a threaded shaft emerging at the bottom of the hole and held by a chrome lock nut. Unfortunately, I cracked the paint around both holes while trying to snug these down and went to another system. Anyone using this type of mirror should come up with a way to avoid what happened to me. Because of a couple of sports misadentures, first golf, then tennis, etc., I have only one eye, the left one. I find an autobahn mirror that mounts with a suction cup on the lower left corner of the windshield plus an inexpensive additional mirror I mount to the right of the dash-mounted mirror work well for me. We Floridians rarely install our hoods (tops), so I don't know how adequate my system will be with the hood mounted. I have an autobahn mirror on my Porsche, as well, but there I only use it to see if anyone is alongside me when I change lanes. It serves pretty well as a general rearview mirror on the Healey. The Harley mirrors are available.
maxwedge5281
maxwedge5281
steve, did you remove the original side curtain mounting hardware to mount the mirror. Or, did you leave the original hole mounting in place?
steveg
Maxwedge - not sure what you mean. I've always had a hole in the body through which my current Raydyot mirror is attached. It is outside of the sidescreen so it still works in the rain. I never mounted the Lucas mirror that way - all I'm saying is it can be done. The mirror must be removed in order to install the sidescreen and vice versa.
John Turney
The original side curtain mounting hardware should remain in place. It keeps the door skin from being deformed when one tightens down the mirror nut.
maxwedge5281
maxwedge5281
steve, john answered my question. thank you for the picture. is the raydot available and where? thanks for the replies.
steveg
Raydyot-style mirrors are widely available in a variety of finishes. I bought a brushed -aluminum version from the UK (Maybe Holden's - can't remember) which has a gently convex mirror which I really like. The finish was originally like a zippo lighter. I buffed the hard varnish off for a natural polished aluminum look. I also replaced the #8 sheet metal screws with rivet nuts for #6 machine screws for a less clunky look.
If you like the polished look, these look like a good bet:
maxwedge5281
maxwedge5281
steve did you take a second mirror...the curved part...and adapt to the raydot mirror>
steveg
Mine happened to come with a slightly convex mirror. But there are convex mirrors out there the same diameter. Blind spot mirrors tend to be severely convex. I think the Brits use a slightly convex mirror on the passenger (left) side.
I actually adapted one of these convexes which I bought off Amazon. It was thicker so I had to elongate the two screw holes to accommodate the thickness. When I bought my Raydyot, I didn't realize it was convex - it looked flat - that's why I went to the trouble of ordering a convex for it.
I'd gotten used to using a convex Lucas on my driver side. They have a nice field of view and because of their design the mirrors can be switched between the LH and RH posts.
Before buying a Raydyot, I'd try to inquire if it's available in convex.
Addendum: This appears to be the mirror I ordered:
https://tinyurl.com/y82ydvgq
maxwedge5281
maxwedge5281
steve, i hate to belabor this but i am speaking of the curved arm attached to the raydot mirror...not the convex lens?. i have not seen a raydot mirror with a curved arm similar to lucas mirrors.
steveg
Max - apologies for not being clear! My Raydyot is mounted with the attached base that shows in the product pix above. It is mounted in a hole drilled in the bodywork which is a few inches outboard of the position of the side curtain.
I dug out my old Lucas mirror, which I'd disassembled in order to get into the box. I pulled out the post (the curved arm) and positioned it separately into the side curtain hole so as to demonstrate that the Lucas mirror would work in the side curtain hole. What you're seeing is me holding the curved arm in position for the pic, next to my Raydyot mirror which is bolted to the door.
maxwedge5281
maxwedge5281
thanks steve! that curved arm was throwing me of. I appreciate your help!
maxwedge5281
maxwedge5281
randy do you have a larger view of the car...trying to get a better perspective of how the mirror looks! ive got my bn6 running and putting in a new interior. I don't like the way it sounds. hopefully the glass packs will burn out!
Bayless More Prefect Progress Other British Cars 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB More Weber help needed MG 27
DrEntropy More lessons in Japanese engineering Other Cars 7
KVH General Tech More Technical Questions—TR4 Triumph 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech More Engine Rebuild Questions Triumph 15
AngliaGT A Few More Spotted 6
AngliaGT Saw a Few More Spotted 0
Bob Claffie More Village pics Other British Cars 0
Bob Claffie More Village pics Other Cars 3
M TR6 More noob questions… Triumph 14
Bayless More Paint Other British Cars 3
AngliaGT A Few More Local Vehicles Spotted 5
Basil More BMW Z4 trials Other Cars 21
AngliaGT A Few More I saw Yesterday Spotted 10
SteveTheBrewer Spitfire More rust repair Triumph 1
AngliaGT A Few More along Highway 220 Spotted 3
Bob Claffie More pics from Falls Village Festival Other British Cars 3
Sherlock Another cruise night, more interesting British iron Spotted 2
Y MGB More things that seem odd.... MG 2
D TR2/3/3A More Fuel pump questions. Triumph 10
jlaird MGB More on Bee's status MG 6
AngliaGT A Couple More Spotted 0
tr6nitjulius TR6 TR6 meeting my Demands & Giving Back more! Triumph 2
tr6web TR6 More leg room needed Triumph 5
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
Nelson No more MG Midgets Spridgets 3
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
K TR2/3/3A Auxillary Carb Return Spring in More BS about TR's. Triumph 0
K TR2/3/3A More pics of Kast Cam Triumph 4
K TR2/3/3A TR3A SU's More Pics Triumph 0
Ripper01 For Sale more TR-6 Used Parts Oct 2019 Triumph Classifieds 0
lbcspinners A- H Frog E: no more Bugeye oil leaks! Austin Healey 4
7 No more Bosch tools for me Restoration & Tools 4
D TR2/3/3A More small nuts [ and studs!] Triumph 2
C TR6 More fun with Lucas Triumph 5
Bayless More Sprite progress finally Spridgets 23
Bayless Even more progress - the Prefect Other British Cars 5
Bob Claffie T-Series More or less TD action MG 0
R More Shroud to Scuttle install Austin Healey 4
Y MGB Answer to a question creates more new questions.... MG 12
K TR2/3/3A Auxillary carb return spring in "More BS about TR,s" Triumph 9
S TR2/3/3A little more door gap Triumph 14
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
D BT-7 tri-carb Two more questions Austin Healey 18
R TR2/3/3A One more crank pulley question Triumph 7
K TR2/3/3A More electrical....the Starter? Triumph 8
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
