I have put a set of Volvo HS6 on a TR6. I had to invert the carbs because there was interference between the bowls and the linkages.
The car looks allways rich.
Is there a difference between the front carb and the rear carb? Can this cause the richness problem? Sould I reinvert them and work on the linkage clearance?
Any expert advice should help.
Thanks
YH
Thanks
YH
