Throttle pedal problem
mgtf328
As I've only just bought this car I don't know if this is normal for a BJ8 but when I press the accelerator nothing happens for the first 1 -2 inches. It's just a dead spot then the engine picks up smoothly as you'd expect. I've replaced the bush at the end of the pedal shaft and tried different positions for the lever arm on the end of the shaft. A mechanic friend of mine has adjusted the linkage as per the manual but nothing seems to alter the dead spot. Has anyone got any suggestions as to what I should try next. Thanks.
AJ
I just went through the whole throttle mechanism adjustment rigamarole with my BJ8. In my case, I was forced to do this when I noticed after I pulled the engine for rebuild that the cross-shaft bushings were toast, and one of them had been bent back (probably at a previous engine removal and install). I also spent a considerable amount of time making sure I got full WOT when the pedal hit the metal. The OEM throttle shaft bushings are bronze bushes embedded in rubber; the rubber was dry and crumbling, causing the shaft to 'absorb' some of the movement of the pedal before it moved the shafts that opened the throttles. I suspect this is less of a mileage-related wear issue, and more of one of time (50+ years of engine compartment heat). So, check for play in the throttle cross shaft, at the top of the transmission tunnel behind the engine. Surprisingly, I didn't see any wear in the 'ball-and-socket' joints that connect the whole Rube Goldberg mechanism, but the ears on spring locks tend to corrode and break off easily.
Moss Motors (NFI) sells a set of nylon/teflon--they call the both/either at different points--bushings to replace the bronze/rubber originals*, and I've heard from some who 'rebuilt' the originals by replacing the rubber part with urethane or similar. Unfortunately, these would be a female dog to replace with the engine in place, though the comprehensive instructions that come with the Moss kit explain a method to make re-install easier.
* These were designed by Eric Grunden, a highly-respected Healey mechanic here in the Colonies:
https://www.mossmotors.com/graphics/products/instructions/021-822_980-310_INST.pdf
John Turney
If you have someone who can press the throttle while you look at the mechanism with the bonnet open (and the car parked), it might give you ideas where the slop is.
When switching to Weber carbs, alterations to the throttle linkage was unavoidable, and after years of dealing with the vagueness and potential failure of the original setup, I concocted a far simpler and direct actuation of the butterflies.
It's not going to fool any concours judges, of course there's so many other infractions, the throttle linkage could go unnoticed...
DerekJ
The throttle linkage set up is a Heath Robinson affair at best. There is always some play in the system and the cross shaft is virtually impossible to access with the engine in the car. I had the same problem with my first Healey, then my second one had the problem where the throttle does not return to fully closed unless you blip the peddle. I recommend switching to the Denis Welch cable throttle system, massive improvement. Used it with both SUs and Webers without any problem and there is much more feel.
Patrick67BJ8
i replaced the original throttle linkage ends with Rod Ends that Toms Imports sells. No slack in the gas pedal linkage anymore.
DerekJ
Yes Heath Robinson was ~Rube Goldberg's cousin!
Here is his drawing of the Austin Healey throttle system.
fordtrucks4ever
Isnt that what the Milton Bradley Mousetrap game is based on?
A Throttle Pedal Height Austin Healey 17
tmcarthur Throttle Pedal Lever Spridgets 7
Brosky Throttle pedal and bushing page done Triumph 4
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 31
Walter74 Throttle Cable Conversion Austin Healey 6
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
K TR2/3/3A Kangarooing on light throttle Triumph 14
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
catfood Throttle return mechanism on the BN1 Austin Healey 4
RickPA Overdrive throttle switch caused meltdown Austin Healey 2
bighealeysource Strange problem with throttle staying open Austin Healey 6
Bob_Spidell Throttle Bushes Austin Healey 6
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rob Glasgow Overdrive Throttle Switch Austin Healey 9
Rut TR4/4A SU throttle linkage and brackets Triumph 5
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
Lukens TR2/3/3A Anyone ever see a push/pull throttle mounted on the dash? Triumph 4
P Bj8 rhd cable throttle conversion - help Austin Healey 6
TomMull Shortening a throttle cable Q&D with stuff in the shop. Restoration & Tools 5
TomMull Spitfire Throttle linksge needed Triumph 10
TomMull Post-War Other Herald carpets and throttle issues Triumph 4
MY66AH Throttle Linkage Spridgets 9
doc50 TR2/3/3A Throttle sticks Triumph 8
J TR2/3/3A Need a part for the throttle shaft. Triumph 4
C Overdrive throttle switch rod connection picture Austin Healey 3
