RHD BJ8 Throttle Control Rods
barnman
Good afternoon chaps. Has anyone with a RHD BJ8 any details of the length of the connecting rods for the throttle controls?
I have converted L to RHD and the setup needs new rods. The manual just shows a LHD arrangement.
If anyone could supply approx measurements ball joint to ball joint, that would be most helpful as a starting point as the threaded rods available have to be cut to length from scratch.
Thanks in anticipation.
Regards Al
mgtf328
I measured centre to centre on each of the ball joints. The one on the carb = 8 cm, the one to the carb side of the rod under the dash = 11 cm and the one from the rod under the dash to the throttle pedal = 16 cm.
Well that's what mine are. Can't guarantee yours will be the same as every Healey is different!!!!
AJ
B
barnman
AJ
Thanks for doing that, hope the rain has stopped. Have set mine up roughly but will now measure and compare to your settings. It obviously has an impact on the angles of the levers etc.
When I had my last car 25 yrs ago AH Spares had them on the shelf..alas no more.Interestingly I spoke to John, sales manager at AHS who had a set on his desk poss with a view to remanufacture . I guess if enough enquiries they would crack on!
Thanks again
Al
B
barnman
Just an update....my set up is similar though the rod from the manifold to the carbs is quite a bit longer. I can adjust this though to something similar to yours!
I have fitted a fast flow manifold from AHS ..AKA Rawles the supplier so could account for a few differences?
Thanks again AL
mgtf328
The 11Cm and 8Cm rods.
steveg
Re upper picture. Don't like the 3 o'clock position of the arm while at rest. Wide-open this puts it too close to 6 o'clock and danger of over-center stuck open throttle. IMO at rest should be more like 2 o'clock such that at wide open throttle it would be "at least 20 degrees short of the vertical position".
Setup described with drawings in Bentley manual section A.37, pp 55-56.
P Bj8 rhd cable throttle conversion - help Austin Healey 6
S BJ8 Tires & RHD conversion Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
M MGA RHD twin cam steering pinion MG 0
M MGA RHD MGA dash finisher MG 0
T Wanted Bugeye Sprite RHD tonneau cover. Austin Healey Classifieds 0
M MGA RHD rack and pinion wanted MG 19
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B LHD to RHD accelerator controls Austin Healey 15
simon1966 Brake fluid Canister on a RHD 100 Austin Healey 10
simon1966 Pedal box blanking plate for a RHD Frog Eye Austin Healey 5
T 100-6 LHD/RHD mystery Austin Healey 7
M TR4/4A What modified carby air filters to use on my TR4 RHD. Triumph 19
I TR6 69 TR6 pi rhd Triumph 8
tinman58 TR5/TR250 RHD Steering Rack Triumph 0
D RHD Morgan Spotted 0
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
T TR4/4A RHD TR4A in PA- Does anyone have any information about my old car? Triumph 3
Gray_Cat T-Series 1949 RHD MG TC For Sale MG 3
PatGalvin TR2/3/3A RHD Steering Column Hole Blanking Plate Triumph 6
HealeyRick First RHD Austin-Healey Austin Healey 12
Rut RHD conversion Spridgets 21
AN5Sprite RHD square body project car Spridgets 5
aeronca65t Roadster-RHD, wire wheels-not British Other Cars 3
rustrocket Triumph 10 Sedan. RHD conversion? Triumph 1
B Accelerator relay rods on RHD Austin Healey 2
A Wanted RHD dash, fiberglass bonnet Spridgets 6
F RHD Clutch Pedal Jaguar 1
drooartz MGB-GT Hunting for a RHD B or BGT MG 30
drooartz sorta kind ish maybe looking for a RHD Bugeye Spridgets 8
eschneider Morgan for sale: 1974 4-seater RHD 4/4 Other British Cars 3
jaegzie Ford Probe gt -- RHD help needed. Other Cars 4
QuickSilver A Flight Of Fancy: RHD Conversion MG 5
JPSmit RHD Sprite for sale Spridgets 5
drooartz RHD vs LHD hydraulics Spridgets 2
Strapping_Lad Spitfire LHD to RHD Conversion on '63 Spit Triumph 6
D RHD MK2 right knee support Jaguar 8
John Moore Bugeye Seat Bottoms / RHD Dash Spridgets 1
John Moore RHD Conversion Spridgets 14
John Moore RHD Steering Rack Spridgets 4
Tom74TR6 MGB-GT 1981 RHD GT from the UK engine question MG 9
W RHD Conversion Spridgets 15
B GT6 Searching for a white RHD GT6 MkIII Triumph 1
M Converting to RHD Austin Healey 8
aeronca65t RHD Mustang Other Cars 11
healeynut T-Series MGA / MG TD steering rack [RHD] MG 4
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
healeynut LHD to RHD Jaguar 1
