TR4/4A Throttle Linkage
Popeye
Bronze
Hi all,
I am near completion on my TR4A assembly, crossing off the last items on the “to-do list”. My throttle linkage is a bit sticky. If I push the accelerator pedal, it does not (always) return.
I have not yet debugged the problem. (I replaced the bushings and three springs with new during assembly.) I plan to take apart one joint at a time and see where the “sticky bit” is; hopefully I can isolate it to one joint, not several.
However: what is the correct procedure for installing the adjustable links? Parts 14 and 145077, parts #10 and 13 in attached image. They thread into a mating piece, and a lockwasher plus nut are threaded on. Should the threaded part be screwed tightly to the mating part, followed by a tight nut? Or should the threaded part only be tightened a little, allowing space between the moving surfaces and the nut used as a locknut?
Also, I assume the ball joints in the links should be lubricated? (With graphite??)
(SU HS6 carbs)
thanks!
charleyf
Hi all,
(SU HS6 carbs)
thanks!
I use the HS6 carbs and this linkage on 2 TR4s and a TR3A. The answer to your question IMHO is that the threaded bolts or studs that you refer have a lock washer and should be tight not loose.
Where I have found problems has been with bolt 16 and nut 19. I have replaced lock washer 18 and replaced it with a flat washer. Then have used a lock nut. Just make sure this step bolt functions and is not loose or wobbling. And the fulcrum sitting on the step bolt is not wobbling.
Lubrication of the ball joints should be grease.
If your pedal is not returning to full off, my first place to look is at the two springs shown in the picture and then the spring on the accelerator shaft.
To me any loose joints in this system cause slow response when the pedal is depressed and also prevent a full off when pedal is released.
Charley
Popeye
Popeye
Bronze
Thanks Charley. I’ll check 16/18/19 - I believe I reused original hardware… it might be out of round, etc.!
charleyf
The fulcrum and ball joints wear as well. The ball joint can be tightened if need be also.
Charley
Popeye
Popeye
Bronze
And the verdict, as Charley predicted, is the fulcrum pivot. Stiff. I’ve ordered new, assuming the original part is no longer “round” - and not terribly expensive.
Thanks!
Fingers crossed…
charleyf
Thanks!
Fingers crossed…
My advice would be to replace fulcrum and step bolt/ pivot. Not just one part.
Charley
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
CARSINC Throttle linkage question Spridgets 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 30
C Jammed Throttle Linkage Austin Healey 3
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
ckeithjordan TR2/3/3A H6 Throttle Linkage Triumph 13
T Looking for advice for throttle linkage for Weber DCOE Spridgets 2
Rut TR4/4A SU throttle linkage and brackets Triumph 5
MY66AH Throttle Linkage Spridgets 9
B Longbridge 100-6 Throttle Linkage Pictures - Any Out There? Austin Healey 27
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
newmexTR3 TR2/3/3A TR3 Throttle linkage pics needed Triumph 19
H TR4/4A 4A Throttle linkage for HS6 SU Triumph 2
A TR4/4A TR4A Throttle - Lower linkage length Triumph 1
vette Throttle Linkage Ball Joints Austin Healey 5
T Keeping the throttle linkage shiny Triumph 5
DrEntropy Alfa throttle linkage? Other Cars 3
MrBlueSky Wedge tr8 edelbrock throttle linkage Triumph 2
R GT6 Need to see GT6 Mk1 Throttle linkage Triumph 9
drooartz Throttle linkage question Spridgets 6
Zimmycobra Throttle linkage saga continues Triumph 5
Zimmycobra TR4/4A TR4A throttle linkage Triumph 6
Got_All_4 TR5/TR250 TR250 throttle linkage problem Triumph 6
T TR2/3/3A TR3 Throttle linkage return spring Triumph 3
D Ratco Throttle Linkage Triumph 8
J Healey 3000 - throttle linkage [cable] Austin Healey 11
T TR6 Picture/diagram of TR6 throttle linkage Triumph 7
bighly Improved throttle linkage MG 1
philman Wedge TR8 Throttle Cable linkage help Triumph 3
G Throttle switch and linkage Austin Healey 5
T Throttle linkage question Triumph 2
chicken Throttle linkage for BJ7 Austin Healey 6
B BJ7 Throttle Linkage Problem - Access? Austin Healey 6
D Ratco Throttle Linkage Triumph 31
vping Throttle linkage - I need a pic MG 13
chicken RHD Throttle Linkage Assembly For BJ7 Austin Healey 2
S HS2 SU dual carb throttle/choke linkage Spridgets 10
tosoutherncars DGV throttle linkage help needed Spridgets 4
X Throttle linkage sticking Spridgets 6
DrEntropy YO! Brosky!!! [RE: Throttle linkage couplings] Triumph 15
Brosky Throttle linkage from Ratco Triumph 35
P Throttle linkage on 1967 LHD. BJ8 Austin Healey 5
ronzet Hot Throttle Linkage [I've got a weird one...] Austin Healey 15
G Triple Stromberg throttle linkage Triumph 12
S Adjusting Throttle Linkage Austin Healey 3
mbrooks BN2 throttle linkage Austin Healey 1
Lin Carb Linkage and Throttle Cable Austin Healey 3
