Carb Linkage and Throttle Cable
Lin
Hello all,
As some of you know I have been fooling around with a conversion from the mechanical throttle linkage to a throttle cable for some time. I have done some experimenting but have been less than satisfied. The atached image is of Jack Brashear's car. I like the "over the top" cable as opposed to the "under the carbs" route that most other approaches I have seen use.
Is the part circled in red from a TR6? Anyone have a name, part number or even better, know where I can source the part? If not from a TR6 can anyone help identify the part?
Thanks for the help?
Lin Rose
1960 BT7 in restoration
1959 Bugeye
Keoke
Well Lin, it looks just like the throttle cam off of a Volvo fuel injected car.The appearance of which made its debut in the P1800E series car. I noticed his cable was quite taut.However, there is a small bracket that bolts to the cam which keeps the cable from jumping off and allows a bit of slack in the cable so as not to impede the idle adjustment---Fwiw---Keoke
100DashSix
I was going to say, that looks exactly like the gas-pedal-linkage device on my 1988 240 Volvo.
Keoke
Yep /ubbthreads/images/graemlins/iagree.gif100Dash6,all the B20 and B21 series fuel injected engines used that type cam. There are two types as I recall, one is stamped metal and the other is a heavier cast item .If you know how to do it You might post a piccy of it for Skip.--- /ubbthreads/images/graemlins/cheers.gif-Keoke
S HS2 SU dual carb throttle/choke linkage Spridgets 10
Lin Carb throttle linkage Triumph 11
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
doc50 73 Midget Carb linkage confusion Spridgets 5
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
D BT7 tri-carb linkage set up Austin Healey 23
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
H T-Series Need carb linkage info for my TD MG 1
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
B Carb Linkage Issue [3000 MkI] Austin Healey 6
K TR2/3/3A Su carb rod linkage bell crank stud? Triumph 6
sundown TR6 carb linkage Triumph 7
M TR2/3/3A TR3 carb linkage Triumph 8
B Front carb choke linkage pin Triumph 5
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
TulsaFred 1275 carb linkage Spridgets 9
T TR4/4A Pictures of your TR4A w/ SU carb linkage set up Triumph 7
B T-Series MG TC carb linkage MG 2
Jim_Gruber Accelerator Cable termination on carb linkage Spridgets 10
Tinkerman SU H 6 Carb Linkage set up Triumph 16
tony barnhill MkI Midget Carb Linkage Question Spridgets 27
Bruce_B Picture of Carb Linkage?? Spridgets 6
T Ratco carb cable linkage Triumph 21
T Carb Linkage Conversion Triumph 3
T Carb Cable Linkage Triumph 22
P 1275 & Carb. Linkage for Bugeye Spridgets 4
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
C Carb linkage MG 1
B Carb Linkage Adjustment Tip Austin Healey 1
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
