1275 carb linkage
TulsaFred
Putting the carbs on the rebuilt 1275 that will go in the B/E.
Seems I am missing the choke linkage and possibly part of the accelerator linkage.
Cant find a real clear picture or diagram.
Can anyone post detailed photos of the carb set up?
Thaks much
Fred
TulsaFred
TulsaFred
If anyone has a spare set of choke linkage for dual HS2's let me know and I'll buy.
Thanks
Fred
TulsaFred
TulsaFred
How 'bout this
There are three return springs from linkage to heat shield.
. Two long and one short
Where do they go?
Fred
JPSmit
TulsaFred said:
How 'bout this
Where do they go?
Fred
Mine (I only have one and need to get another) goes to the triangular cutout on the inner fender. Don't know if there was ever really "a place" just a spot to hook it on.
The_architect
Fred--these photos are pretty bad, but they might help. The choke cable stop is something someone improvised. It doesn't work quite right.
Charlie
The_architect
Fred--
This shot of the linkage on another fellow's car appeared on the MG Experience website this week. Hope he doesn't mind I post it here. I'll take it off it he does. Disregard the arrows.
Charlie
Short springs to each butterfly. Long Spring to the throttle cable linkage.
TulsaFred
TulsaFred
Awesome,
I love you guys!
that's just what I needed
P 1275 & Carb. Linkage for Bugeye Spridgets 4
R 1275 engine with SU HIF single carb Spridgets 9
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
R 1275 timing/ carb pistion sticking Spridgets 3
R Carb differences 1098 and 1275? Spridgets 6
Bruce_B HIF44 1.75" carb/1275 with PICTURE & question Spridgets 3
Bruce_B HIF44 1.75" carb on 1275 engnie Spridgets 4
Bruce_B HF4 Carb on my 1275 '59 BE Spridgets 0
Z 948 carb on 1275? Spridgets 12
aeronca65t Single Carb 1275 Spridgets 6
CARSINC WANTED: 1275 Engine Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D A distributer question on the 1275 engine. Spridgets 7
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
M Proper running temp for 1275 Spridgets 28
