Carb differences 1098 and 1275?
radibob
I think I have a needle issue. Here's the deal. I rebuilt a 1275 for my 66 sprite which had a an early 1098 in it (previous engine swap from PO).
Since both engines used the HS 2 SU carbs I used the same carbs, but I haven't been able to adjust the *&^%$ things.(I have used color tune and a carb balancer) They are OK at idle but it will miss and buck at higher speeds. The 1275 is a late one from which I removed the air pump and plugged the holes etc etc.
The ignition is all brand new with Petronix and the right rotor etc.
Any previous experience with this one? different needles? damper springs I am all ears?
Pythias
Let me start by saying that I'm not an expert or even very knowledgeable about this stuff, so wait for a real pro to weigh in. I'll await the answer as well,.....but my understanding is that all the bodies are the same, the differences coming from fitting proper springs and needles.
The book shows the spring to be "BLUE" and the needle to be "AN" in all applications from 1098 thru the 1275, EXCEPT for 1275s-12V778F/H101- from very late cars, in which case, needle AAC.
Woblynne
Member
I have an early 1275 (UK spec) which has the same carbs as the 1098 (tag number AUD 136) so it should run ok with the those carbs, You could try refitting the points/condenser etc to see if theres a problem with the pertronix as it seems to play up when you're asking more from it?
Mark
R
radibob
Yeah that's a good idea that I have been trying to avoid but the petronix is the only thing that I haven't touched yet.(long sigh)
Dug
There are differences in the needles. Figuring all the past owners, who knows what needles you have. But none the less you will need the proper set of number / letter size for the cc displacement. The jets can be different as well. What color band is on the jets now?
Dug
Billm
Of course you have checked that there is oil in the dash-pots and that the carb pistons move freely?
Bill
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
O HD8 carb on Healey 3000 Austin Healey 62
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
R TR2/3/3A Carb throttle return spring tension Triumph 2
drooartz MGB Troubleshooting Mikune carb MG 33
