SU H 6 Carb Linkage set up
Tinkerman
Does anyone have a picture of their carbs, sans air filters, that show a frontal view? I sure could use it to check linkage and fittings.
Thanks, Tinkerman
T
Tinster
Thanks, Tinkerman
I hope these photos don't tick off too many folks
but it seems you can use them.
I hope these photos help you a bit
The Fisherman
Tinkerman
Tinkerman
Hi Dale, thanks for the pics. Unfortunatly I need pics of the SU H6 and the ones you posted are for the Stromberg carbs. Appreciate you posting them, they sure are purdy.
Thanks, Tinkerman
Brosky
Dick,
If you are looking for HS6's or HS8's which differ from the ZS-CD's that come stock, Shannon has made the switch and I'm sure that he can help you too.
Shannon's HS8 Installation
LastDeadLast
Thanks, Tinkerman
Tinkerman,
Here is a pic of my HS8's it may be close depending on where you're fuel bowls are. I'm using the RATCO linkage also.
-s
NickMorgan
Not sure if these will help, but all I have on the PC just now. If there is anything in particular that you are needing a picture of, I could be persuaded to go out to the garage with my camera!
NutmegCT
Dick - the best picture of the H6 setup I've seen is in the operator's manual - believe it or not.
I'll scout around for mine. I also think I posted it here about a year ago ...
Just a sec ...
Tom
Brosky
Well Shannon, now I can see why yours could be louder at WOT with the HS8's than the tri ZS.
What size diameter are those throttle ports? Nice air filters too. (on your other thread, that is!)
NutmegCT
OK - that pic is on p. 35 of the "practical hints" manual. Let me know if you need a scan of it and I'll post it here.
The picture is taken from slightly below the carbs, looking toward the block. Good view of the choke linkage setup if that's helpful.
Tom
NutmegCT
Here you go - hope the resolution is good enough for you.
PS - I emailed you a much better pic. Forum wouldn't allow that large file to be posted here.
TR4nut
Somebody will likely chime in a lot better on this, but I seem to recall that the choke connection is a little tricky and non-intuitive to get just right. If I dig up the facts to back up that faulty memory I'll chime back in.
Also, I have a complete/original H6 setup on a manifold in unmolested condition if you need more pictures - choke hookup/final throttle hookup is not present though.
Randy
Brosky
WHOA BIG time air flow.
You did have the manifold ports opened up / modified? Who did the work?
LastDeadLast
Jeff Palya did the work. He sold me the carbs and found a late model intake to bore out. He also included a modified linkage which worked ok, but I installed the Ratco kit and a set of Rover 2000 throttle return spring retainers along with the choke setup.
DNK
Shannon- GET that camera down at throat level and take a mess of photos for me. One of these days I will need to get my SU 6's hooked up.
TexasKnucklehead
I'm going to use a set of H6S's and a (longer) intake I got off ebay on my TR3. The linkage had to be converted to "pull from center" instead of "pull from front". I had to grind a little off of this TR6 throttle linkage (near the bolt hole to allow full throttle), but otherwise it looks like it will work.
D BT7 tri-carb linkage set up Austin Healey 23
T TR4/4A Pictures of your TR4A w/ SU carb linkage set up Triumph 7
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
doc50 73 Midget Carb linkage confusion Spridgets 5
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
H T-Series Need carb linkage info for my TD MG 1
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
B Carb Linkage Issue [3000 MkI] Austin Healey 6
K TR2/3/3A Su carb rod linkage bell crank stud? Triumph 6
sundown TR6 carb linkage Triumph 7
M TR2/3/3A TR3 carb linkage Triumph 8
B Front carb choke linkage pin Triumph 5
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
TulsaFred 1275 carb linkage Spridgets 9
B T-Series MG TC carb linkage MG 2
Jim_Gruber Accelerator Cable termination on carb linkage Spridgets 10
tony barnhill MkI Midget Carb Linkage Question Spridgets 27
Bruce_B Picture of Carb Linkage?? Spridgets 6
T Ratco carb cable linkage Triumph 21
T Carb Linkage Conversion Triumph 3
T Carb Cable Linkage Triumph 22
S HS2 SU dual carb throttle/choke linkage Spridgets 10
P 1275 & Carb. Linkage for Bugeye Spridgets 4
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
C Carb linkage MG 1
Lin Carb Linkage and Throttle Cable Austin Healey 3
Lin Carb throttle linkage Triumph 11
B Carb Linkage Adjustment Tip Austin Healey 1
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
