TR6 carb linkage
poolboy
It's in both the Haynes and Bentley Manuals..Look in the "Fuel System" chapter.
Bob_Muzio
Unless you're going for originality I'd consider a cable mod. It removes much of the play.
DougF
I agree with going cable. It also gives you a little more peddle. If you go that route, lubricate the shafts because they can hang up a little at full throttle.
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
doc50 73 Midget Carb linkage confusion Spridgets 5
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
D BT7 tri-carb linkage set up Austin Healey 23
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
H T-Series Need carb linkage info for my TD MG 1
K TR2/3/3A Auxillary carb linkage return spring? Triumph 2
B Carb Linkage Issue [3000 MkI] Austin Healey 6
K TR2/3/3A Su carb rod linkage bell crank stud? Triumph 6
M TR2/3/3A TR3 carb linkage Triumph 8
B Front carb choke linkage pin Triumph 5
M WTB: Tri Carb Choke Linkage Parts Austin Healey 8
TulsaFred 1275 carb linkage Spridgets 9
T TR4/4A Pictures of your TR4A w/ SU carb linkage set up Triumph 7
B T-Series MG TC carb linkage MG 2
Jim_Gruber Accelerator Cable termination on carb linkage Spridgets 10
Tinkerman SU H 6 Carb Linkage set up Triumph 16
tony barnhill MkI Midget Carb Linkage Question Spridgets 27
Bruce_B Picture of Carb Linkage?? Spridgets 6
T Ratco carb cable linkage Triumph 21
T Carb Linkage Conversion Triumph 3
T Carb Cable Linkage Triumph 22
S HS2 SU dual carb throttle/choke linkage Spridgets 10
P 1275 & Carb. Linkage for Bugeye Spridgets 4
DenverMGB Weber Carb 32/36 DGV - Choke Linkage? MG 18
C Carb linkage MG 1
Lin Carb Linkage and Throttle Cable Austin Healey 3
Lin Carb throttle linkage Triumph 11
B Carb Linkage Adjustment Tip Austin Healey 1
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
