Triple Stromberg throttle linkage
grossgo
Member
Did I read a post on this forum about a throttle linkage kit for the triple Stromberg set-up that is an IMPROVEMENT over the stock/Goodparts one?
OR was I just dreaming? /ubbthreads/images/graemlins/crazyeyes.gif
Thanks, GT Ross /ubbthreads/images/graemlins/canpatriot.GIF
Brosky
I did see a linkage article too, but can't find it right now. I'll keep looking and perhaps someone else will remember in the interim.
Bill, did you post that article or reference?
G
ratco make it.
they are sponsors here.
wait 2 weeks and i'll post pics of it.
or i think tr6bill has it on already. you might prevail on him...
Brosky
See, I knew Bill was at the bottom of this........
martx-5
There's pics at Ab's website ...the guy who developed the cable set-up.
/ubbthreads/images/graemlins/driving.gif
G
grossgo
Member
[ QUOTE ]
I've got it... I love it. Would anyone like pics?
[/ QUOTE ]
Yeah!
I'd LOVE to see 'em /ubbthreads/images/graemlins/eek.gif
But more important: does it WORK? /ubbthreads/images/graemlins/cheers.gif
GT Ross
Brosky
If Shannon didn't feel good about it, you'd hear that side as well. When he says he loves something, it must be pretty decent.
LastDeadLast
With the old linkage, I never liked it to begin with... lots of slop and it just looks like it wants to break.
The Ratco version is very solid and for the first time, I have 100% of my throttle with the triple ZS setup. I did have to trim the mounting bracket because it interfered with a cooling hose, but other than that the install went well.
Here's a couple pics of the kit and the finished product:
and:
G
grossgo
Member
Shannon
Thanks for the pics /ubbthreads/images/graemlins/thumbsup.gif. I think I may order me up one of those.
And now for a completely different topic:
How do you like your Focus SVT? I've been searching for one (gotta be a four....I mean FIVE door though) to replace my Contour SVT, which is a very fun car to drive. I took one for a ride a year ago, and really liked the way it drove on the highway, but didn't move on it. I didn't know they would be so few and far between in the Auto Trader...... /ubbthreads/images/graemlins/nopity.gif
Thanks /ubbthreads/images/graemlins/cheers.gif
GT Ross
SkinnedKnuckles
All it takes is a little bending of the shaft to make the stock work fine.....
LastDeadLast
I must have had that linkage off 6 times; Bending and adjusting...I could never make it work well. I could never get 100% throttle and it always had a lot of slop.
The Ratco setup cured all of that. Bill (TR6Bill) had the same problems.
G
[ QUOTE ]
[/ QUOTE ]
Roger that. The Ratco (Ab's) cable does the trick.
Bill
Trick6 Triple Stromberg Needle Size Issues Triumph 9
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
G Triple Weber DCNFs on 280i V6? TVR 1
H Triple Weber 45's Tipp? Austin Healey 2
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
Simmo TR6 Triple Webers on TR6 Triumph 7
davidb BT7 triple carb question Austin Healey 15
J Triple Webers Austin Healey 19
B triple carb needles? Austin Healey 2
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
B Triple carb setup too rich? How to adjust? Austin Healey 3
M TVR 2500M Triple Weber 40 DCOEs TVR 130
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
S Tuning Triple SU's Jaguar 6
1 07 Triumph Daytona 675 converted to Street Triple British Motorbikes 5
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
B Spridget Triple Master Setup Racing 5
B Brake union Switch Triple Master HELP!!!! Racing 5
B performance increase from triple strombergs?? Triumph 33
D triple carb conversion Jaguar 3
G Modifying the triple intake choke/throttle setup Triumph 18
hondo402000 vacuum advance for triple webers Triumph 2
MadRiver High praise for Triple C Triumph 5
L triple SUs Jaguar 1
D Triple Carb Intake Triumph 8
D Triple Strombergs Triumph 15
T Triple Whammy for Crypty & Pedro Triumph 12
B Air Filters for Triple Webers, BT7 Austin Healey 9
Brosky Choke cable question on Triple ZS setups Triumph 6
Brosky All the pics for Micropolish Triple Carbs Triumph 7
Brosky New project, triple carbs, micropolished complete Triumph 21
S Triple Strombergs or Triple Webers Triumph 15
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
M 69' E-Type triple SU conversion Jaguar 5
hondo402000 Goodparts Triple Carb manifold for sale Triumph 0
hondo402000 Goods parts triple cars manifold for sale *DELETED* Triumph 26
G TR6 Question for TR6 triple carb owners Triumph 21
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
tony barnhill Triple-Carb Interchanges [was "Dumb Question"] Austin Healey 2
G triple zs air filters - any ideas? Triumph 4
G TR6 Anyone running triple ZS on a TR6? Triumph 6
DerekJ Triple SU's Jaguar 2
TR_JOE250 TR5/TR250 Need info for fitting triple ZS carbs to TR-250 Triumph 7
S Richard Goods Triple Carb intakes. How good? Triumph 18
A Triple carb set-up Triumph 1
DerekJ Triple 3/4" SU's HD6 Austin Healey 12
