TR5/TR250 Need info for fitting triple ZS carbs to TR-250
TR_JOE250
I don't know if I'll do this, but I have seen it done on a TR-6 and a GT-6 and it sure looks cool. If anyone has any info regarding this,where to get manifold and linkage, performance compared to webbers etc. I'd apreciate it.
Thanks /ubbthreads/images/graemlins/cheers.gif
Ab Crevoiserat
Re: Need info for fitting triple ZS carbs to TR-25
go to Goodparts .com. He has the whole set up for ZS and SU's. If you don't like the linkage set up contact me. I am developing a Throttle cable set up the works pretty nice. I've had some trouble getting the brackets right but all the bugs should be worked out this weekend and ready for sale. If you like you can go to www.abstr6.com and you will get an idea of what I'm doing. Good Luck. And yes to all of you guys that have sent me emails about this I thank you for your paitence.
Andy Blackley
Joe: As Ab mentioned this is the place to look: https://www.goodparts.com/parts_strom.html
I am also working on this setup. I have already ordered mine from Goodparts. It will take 4 to 5 weeks for delivery I am informed. If you use the stock Z-S carbs you can simply reuse the linkage. All you really need in a third carb and some air cleaners.
I also specified an additional port on the manifold to retain the Smiths "mushroom" PCV, which you will also need to do if you are using the orginal 3150 CD175SE carbs, as these earlier carbs have no provision for a crankcase breather hose. I happen to prefer that valve, as I find it does the job very well, and in any case I am going to be using early 175CD carbs from the TR4. These carbs are fairly simple and do not have some of the later emission modifications that can make the later Z-S carbs a pain to use, especially if they have not been rebuilt.
The early Z-S have adjustable jets like SUs, use the same air cleaners as SUs (I am using pancake K&Ns), and have a very nice choke setup, but they do require a different throttle linkage, hence I am one of those waiting (patiently!) for Abs throttle brackets.
PS To those who already are using the triple carbs, which metering needle are you using?
G
[ QUOTE ]
[/ QUOTE ]
Andy, you need to mention the throttle shafts will have to be modified, especially the middle carb needs a new, longer shaft. Too, the triple setup does not use that little "buffer" spring device between the stock dual carbs, just two stock "zig-zag" spring clips to lock the three shafts together. I had three like Strombergs rebuilt for my setup. The throttle shafts appoximate each other, almost touching where the spring clips hold them as one. The stock, modified (to Richard's specs) linkage is weak at best. That is why I too am awaiting Ab's cable linkage. The problem that I have encounted with using the modified stock linkage is the amount of natural (or because of wear) slop in the system which when I apply maximum pedal I still don't get maximum throttle opening. I can, from under the bonnet have someone sit in the car and in neutral, apply full throttle with the pedal and with by finger, push the throttle even further open and get quite a bit more rpms out of the engine. Thus, I am not able to get maximum acceleration, guessing I am leaving maybe 10% on the table.
Bill
swift6
Yep, Good stuff. /ubbthreads/images/graemlins/thumbsup.gif /ubbthreads/images/graemlins/driving.gif
The throttle linkage is a TR6 weak spot even in original form and remains the weak spot of the Goodparts tri-carb conversion. I am also anxiously awaiting Ab's creation and seeing how it works out. I also agree with Bill about not getting full throttle opening. Neither am I. /ubbthreads/images/graemlins/frown.gif
As to the metering needle question. Many tri-carb owners have had good luck using the stock B1AF needles. I was not so lucky as the altitude that I live it had something to say about it. Joe Curto helped me figure out a new needle for my application. I use B1CE's now. Works like a charm but would need to change needles if I were to move to sea level or there abouts.
Andy Blackley
Thanks for the insights Bill. Since I am still in the "gathering and planning" stages there a bunch of things I'll need to figure out!
I intend to make a mock-up out of a piece of plank, using the manifold gasket as a template, to mount the Goodparts manifolds and the carbs to work out those details before I strip the old carbs and manifold off the car.
My understanding of the middle carb deal was that you have to use a rear carb, remove the shaft, then reinstall it in the opposite direction, and use a threaded extension nut (AM37 in the TRF TR250 catalog, page29) to facilitate the linkage, per Mr. Goods instructions: https://www.goodparts.com/tech_docs/Triple_Stromberg_Linkage.html
Shawn: Richard Good recommends the B1AF for those of us closer to sea level (600 to 1400 ft in the hills of northeast Ohio, northwest PA; Lake Erie is at about 575 ft. above sea level).
The stock C3150 carbs on the TR250 use the B2Y needle, which is richer than the B1AF throughout the range. I was wondering if any one was using that carb and that needle. I have an excel spreadsheet comparing the needle tapers, with charts, of some standard ZS fixed and biased needles, as well as some SU needles. I'll send anyone a copy who wants it.
TR_JOE250
TR_JOE250
I just wanted to thank everyone for all the great info. I hope it's been helpful to others as well. I agree the original linkage leaves much to be desired. I could never get my carbs to open all the way either. It looks like Ab has a pretty good setup.
Thanks again /ubbthreads/images/graemlins/cheers.gif
G
Here are some pics of my carb shafts for what it is worth.
Might give you some insight into what you will be dealing with. The interesting part is these carbs are very tightly linked together, so adjust one, adjust all. Gary Martin in South Dakota did the rebuild on my carbs. You might notice that the front carb is a different model than the rear two, really doesn't matter as long as they are in the same family.
Bill
JimLaney I need some basic restoration info for my first car project Restoration & Tools 20
H T-Series Need carb linkage info for my TD MG 1
JamesH Wedge new to me TR7, need some basic info. thanks. Triumph 2
Gliderman8 TR6 Need battery info please for TR6 Triumph 4
drambuie Need info for Elkhart lake event this summer. Austin Healey 10
I TR6 Need help on 69 TR6 glove box info Triumph 0
S Need to know where to find info MG 1
RickB Need info about Miata seats in Spridget Spridgets 49
toysrrus TR2/3/3A TR3 M/C Blanking Plate: Need some info. Triumph 2
D Overdrive basics - need info Triumph 11
B Need info again- Other British Cars 1
B --NEED YOUR HELP/INFO NOW!!!!!!- Other British Cars 0
B --NEED YOUR HELP/INFO NOW!!!!!!- MG 2
G Need info on powder coat equipment and books Spridgets 5
G Need info on Rover K / 4AGE swap Spridgets 29
S Need info and gasket for a stromburg. Triumph 9
C Need info on gearbox and rear end oil for midget Spridgets 5
C Need Info on air intake flange for midget mkII 65' Spridgets 5
toysrrus "Need Info" on "New" Spridget VIN & Engine No`s: Spridgets 45
R Need paint info/ assistance Triumph 13
J Help, I need some BT7 trans info Austin Healey 3
69sprite Back to work, need some bolt info Spridgets 6
LastDeadLast Need some info - Harmonic Damper Triumph 14
R Need 185/70/15 Tire Info Austin Healey 12
YankeeTR TR2/3/3A I need some info on broken TR2 Lockheed axles..... Triumph 0
C Need info on Whitworth hardware Restoration & Tools 3
bcliff New Owner, need info, parts, and everything! British Motor Corp 5
jlaird Need some info on a Bugeye Spridgets 9
bcliff Post-War Other Need Spitfire/Herald info Triumph 2
Beavis GT6 GT6+ electric vehicle project. Need Info/Advice. Triumph 13
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
