toysrrus
TR3 M/C Blanking Plate: Need some info.
Howdy Folks,
I`ve noticed something that I did`nt even consider or think about until I got my `57TR3 Small Mouth back with the Engine Bay Finished.
Mine has a "Blanking Plate" on the RH side where the M/C & B/C would be mounted if It were a RH drive.
I`ve looked thru Bill Piggotts book & I see "2" kinds of Blanking Plates. One is simply a "Flat" pcs. of sheet metal (Thats what mine is) & there is also one shown with a slightly "Raised Panel" that goes around the entire Plate with a good size "Radii" Inside corners (Mine are just square cut). Which would be correct for a `57TR3 Small Mouth TS21162L?
Thanx Much,
Russ
Howdy Folks,
Thanx Much,
Russ
