triple zs air filters - any ideas?
G
So it looks like I'll have the car back in a couple of weeks or less on the triple zs setup. Remember this is only temporary so I don't want to spend too much, but I realised I have no provision for air filters.
Anyone have ideas for air filter mounts for the carbs?
Can I get trumpets & socks or something similar cheap?
Are there any other options before dropping a few hundred on the Goodparts ram air setup?
Oh and if anyone needs CD175 carbs pm me - I have a bunch of them now - I bought a job lot off ebay and rebuilt one. I don't need the rest.
G
Hey Alan,
I have triple 3" K&N filters on my setup. (The 3" filters will fit with adequate clearance on the right inner fender but you will have to shorten one of the front air cleaner's bolts to be able to finesse it in before tightening.) Not economy filters though. I had the GoodParts cold air induction (not a true ram air but uses negative pressure to suck cooler air into the carb air box) And really didn't care for the "look" of the big-ugly box. Plus I had my bonnet louvered to suck air into the carbs. As you know, filters such as the K&N ain't cheap so if you are hellbent on the GP setup, look at the cheaper air filters offered by the vendors. Velocity stacks are not cheap either, depending on who you buy them from, they cost as much as good K&N's. Plus, if you go with velocity stacks you won't want to take them off because your car will never run that well again! I put mine on for shows or if I want to go out and kick b**t. But the socks aren't true filters, just keep bugs out of the carbs.
Bill
TR4nut
Anyone know if TR4A filters would work? I'd think they'd be similar size to K&N, and a whole lot cheaper.
Randy
TR4nut
Followup, check out vic brits selection for TR4/TR250- some possibilities I think:
air filters
Randy
B Air Filters for Triple Webers, BT7 Austin Healey 9
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
HealeyPassion Getting a bit more space for triple Webers... or EFI Austin Healey 3
R For Sale Italian Triple Weber Set Triumph Classifieds 1
G Triple Weber DCNFs on 280i V6? TVR 1
H Triple Weber 45's Tipp? Austin Healey 2
R Pedal box clearance mod for triple Weber clearance Austin Healey 7
J Wanted WANTED; XK150 Triple Carb linkage Jaguar Classifieds 0
Simmo TR6 Triple Webers on TR6 Triumph 7
davidb BT7 triple carb question Austin Healey 15
J Triple Webers Austin Healey 19
B triple carb needles? Austin Healey 2
A TR6 Triumph TR6 Triple Weber carbs Triumph 9
B Triple carb setup too rich? How to adjust? Austin Healey 3
M TVR 2500M Triple Weber 40 DCOEs TVR 130
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
S Tuning Triple SU's Jaguar 6
1 07 Triumph Daytona 675 converted to Street Triple British Motorbikes 5
Brosky Goodparts Triple Carb Heat Shield Triumph 16
Brosky Triple ZS Owners - new Heat Shield from Goodparts Triumph 7
B Spridget Triple Master Setup Racing 5
B Brake union Switch Triple Master HELP!!!! Racing 5
B performance increase from triple strombergs?? Triumph 33
D triple carb conversion Jaguar 3
Trick6 Triple Stromberg Needle Size Issues Triumph 9
G Modifying the triple intake choke/throttle setup Triumph 18
hondo402000 vacuum advance for triple webers Triumph 2
MadRiver High praise for Triple C Triumph 5
L triple SUs Jaguar 1
D Triple Carb Intake Triumph 8
D Triple Strombergs Triumph 15
T Triple Whammy for Crypty & Pedro Triumph 12
Brosky Choke cable question on Triple ZS setups Triumph 6
Brosky All the pics for Micropolish Triple Carbs Triumph 7
Brosky New project, triple carbs, micropolished complete Triumph 21
S Triple Strombergs or Triple Webers Triumph 15
LastDeadLast Stainless Heat Shield for Triple Carb Manifold Triumph 7
M 69' E-Type triple SU conversion Jaguar 5
hondo402000 Goodparts Triple Carb manifold for sale Triumph 0
hondo402000 Goods parts triple cars manifold for sale *DELETED* Triumph 26
G TR6 Question for TR6 triple carb owners Triumph 21
G How to rig a PCV valve on the Triple ZS setup..... Triumph 8
tony barnhill Triple-Carb Interchanges [was "Dumb Question"] Austin Healey 2
G Triple Stromberg throttle linkage Triumph 12
G TR6 Anyone running triple ZS on a TR6? Triumph 6
DerekJ Triple SU's Jaguar 2
TR_JOE250 TR5/TR250 Need info for fitting triple ZS carbs to TR-250 Triumph 7
S Richard Goods Triple Carb intakes. How good? Triumph 18
A Triple carb set-up Triumph 1
DerekJ Triple 3/4" SU's HD6 Austin Healey 12
