Adjusting Throttle Linkage
sp8
Hi again!
I got some great information on my "getting spark" question but now I have run into another problem.
I have tried to get the accelerator pedal to work and I'm struggling with it. Sorry, I guess I should have told you that this is a 1965 BJ8 with HD8 SU carbs on it. It has mechanical linkage from the accelerator to the carbs. I can freely operate the carbs from inside the engine compartment and I can see all of the linkage working down to where it goes inside the people compartment. However, inside the accelerator acts as if it is seeing none of the action from the carbs. I will replace the springs that pull the carb back to the idle position but the accelerator peddle still feels very spongy and un-responsive. Is there some sort of adjustment that I have to make to the accelerator pedal linkage that will tighten up this response?
Thanks.
Velox
Hi sp8, sounds like your accelerator pedal shaft is loose at the throttle relay rod linkage. I was going thru my 66 BJ8 checking everything and one of the old hot rod items I was taught was make sure your pedal travel is fully opening your throttle at the carb - or FI or whatever. I put my pedal to the floor, well into the carpet furrow from the previous owner's heavy foot action, and at the engine was getting only about 40% travel at the carbs. I traced it down to the connection between the pedal rod where it comes through the body and attaches to the relay rod arm - study the picture below and/or go to Moss website or SCParts website and look under engine controls section www.scparts.co.uk/ and download, enlarge and study the diagrams and look in your Healey manuals. Search here for "linkage" and you will find tons of info. My problem was that the hold down bolt/nut had loosened and I was able to tighten it up even though the working space room there is very limited. Once tightened I then had full travel of the accelerator pedal transmitted fully to the carb linkage giving me 100% throttle. What you describe sounds very similar to what I had. I'm sure one of the regular experts here will respond, they check the forums nearly every day and their answers are incredibly helpful, and also run the search for linkage and you will get pointed in the right direction. Good luck!
S
sp8
Thanks for the information. I am working night shifts and I haven't had a chance to try out these suggestions. Next days off I will give them a try. Thanks!
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
doc50 Adjusting play on steering box? Other British Cars 5
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
drambuie Adjusting steering box with shims Austin Healey 6
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
Darwin Adjusting steering play? Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
T Adjusting valves makes me more crazy. Triumph 18
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
pjsmetana Adjusting the Bonnet and the Bumper Triumph 5
DarwinT Adjusting a Weber carb Spridgets 3
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
