Adjusting steering play?
Darwin
Bronze
I have about 4-5" of steering play at the steering wheel. (2-3" to each side of center. This seems to be consistent throughout the travel of the steering. I have adjusted my driving style so that the inital lag doesn't bother me anymore. However when unloading the steering as when coming out of a corner, I am getting a quick jerk to center as the steering wheel unloads. If I continue to go in the oppisite direction such as in making an S bend I get another quick movement as the gear loads up again. This is the best I can describe it. The play seems to be in the steering rack. Everything else seems tight. Bushings, tie rod ends, etc. are all new. Is there an easy way to adjust for wear in the steering rack?
Thanks,
TR3driver
Great Pumpkin - R.I.P
Not really an adjustment for wear, but I believe there is an adjustment for the pinion/rack engagement. The big nut on top of the rack has shims under it & the workshop manual has a procedure for selecting the shim pack.
Also check that the problem isn't your inner tie rod ends (inside the boots). I'm not positive, but they might have shims as well.
dklawson
Even though it may appear to be the rack itself it may be elsewhere.
Your signature implies this is on a Spitfire. If so, check out the steering column flex joint. It will be on the column just above the rack. There are a whole bunch of rubber washers inside that joint. When they fail you will have the type of play you are talking about. I believe Spitbits had the best price on new joints if this is what it turns out to be.
Andrew Mace
:iagree:
Alternatively, you can probably find suitable rubber washers in a good hardware store for a bit less than the cost of a new joint, since it seems to be only the washers that wear out.
Of course, it could be the rack itself, but it might just be the rack moving due to dying rubber steering rack mounting bushes. That's not always obvious unless you are actually watching the rack while someone moves the steering wheel back and forth.
Darwin
Darwin
Bronze
The coupler was rebuilt when I installed it. I have watched all the connectios as the steering wheel is turned and there is no slop in anything leading up to the pinion shaft. The play all seems to originate in the pinion to rack gear lash. Is the pinion tapered so it can be adjusted into the rack thru the use of shims? If so, where are they available?
Thanks
tdskip
I hope I am wrong, but doesn't this suggest the rack or inner rods have play?
I don't remember any slop on my '74 Spit.
TR3driver
The .002" shims are available from TRF, P/N 120959.
Didn't find a source for the others, but they are P/N 120949 (.004") and 132055 (.010").
PS, but since you remove shims to reduce the clearance, you may not have to buy any more shims.
Darwin
Darwin
Bronze
thanks folks. will check out all suggestions.
doc50 Adjusting play on steering box? Other British Cars 5
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Geo Hahn TR2/3/3A Steering Box Adjusting Screw Triumph 12
drambuie Adjusting steering box with shims Austin Healey 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
AUSMHLY Adjusting Valve Clearance Austin Healey 31
S Testing and Adjusting procedure for RB340 Austin Healey 4
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
BN6_2197 Adjusting Rer Brake of BN6 Austin Healey 2
BN6_2197 Rookie question on adjusting valve clearance Austin Healey 9
Jim_Gruber Adjusting Spridget Doors Spridgets 4
Tinkerman TR2/3/3A TR3 A 1960 adjusting apron Triumph 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
Joe Reed MGB Adjusting the reverse lamp switch... MG 3
vette Adjusting HD8 Carbs Austin Healey 21
M Adjusting Front Suspension Austin Healey 11
HealeyDave HD Carb Jet Adjusting Screw Question Austin Healey 2
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
Jim_Gruber Adjusting Pushrods in Pedal Box Spridgets 5
B Adjusting SU-HD6 Carbs Austin Healey 2
wkilleffer MGB Trouble with adjusting the front SU carb- 74 MGB, HS4 carbs [long] MG 5
S TR2/3/3A little adjusting screw tr3 Triumph 1
F Adjusting gear lever, centershift 3000 Austin Healey 2
L Adjusting the bows before top installation Austin Healey 2
bighealeysource Adjusting toe in on a Healey Austin Healey 8
M Adjusting TR3 regulator Restoration & Tools 1
Scotsman Adjusting clutch pedal travel Triumph 2
R Adjusting Valve Clearances Triumph 13
Moseso TR2/3/3A Adjusting Koni shocks [TR3] Triumph 10
N Adjusting headlights on a BJ8 Austin Healey 2
A Adjusting BJ8 Doors Austin Healey 5
K TR2/3/3A TR3 Fuel Gauge Again.....Adjusting? Triumph 11
B TR2/3/3A 57 TR3 BONNET ADJUSTING SHIMS Triumph 4
brgrmyster TR6 Adjusting TR6 Headlights Triumph 8
M Adjusting idle speed Triumph 28
bighealeysource adjusting the handbrake on BN6 Austin Healey 1
TR6oldtimer Adjusting rockers Triumph 7
hondo402000 TR6 adjusting windows to Wind screen TR6 Triumph 2
T Adjusting valves makes me more crazy. Triumph 18
wangdango 100m bonnet fitting/adjusting?? Austin Healey 4
JohnnyMead Tips on Adjusting the Clutch Slave Pushrod? Triumph 4
pjsmetana Low Idle, DVG adjusting = no dice Triumph 12
pjsmetana Adjusting the Bonnet and the Bumper Triumph 5
DarwinT Adjusting a Weber carb Spridgets 3
bighealeysource ADJUSTING THE HAND BRAKE ON A BN1 Austin Healey 1
Y TR4/4A Adjusting valves on a TR-4 Triumph 4
